Wire jdm b18c into my 96 civic cx first swap need help?
Old Jun 26, 2012 | 10:27 AM
Estuardo1025's Avatar
Icon6 Wire jdm b18c into my 96 civic cx first swap need help?
Ok I have 1996 civic cx I'm using my stock harness but I need help to wire the engine harness and the vtec car is obd2a my ecu p72 I know I need to extend some wires but I'm not sure which one anything will help thanks motor I'm using is b18c obd2a Oh and the radiator hoses won't fit do I need to change it to what kind do I need thanks
Old Jun 26, 2012 | 12:42 PM
Default Re: Wire jdm b18c into my 96 civic cx first swap need help?
Any body I need help thanks
Old Jun 26, 2012 | 02:54 PM
EJ8_Man's Avatar
You'll need to wire more then just your VTEC solenoid. What about your IAB? Are you using a stock B18C motor? Your Dizzy will also need to be wired. As for the wire lengths you should do it while you're installing the motor. See which sensors need to be extended and then do some cutting/soldering
It sounds to me that your attempting a swap, but haven't done the research. Try Googling this swap and see what you come up with
BTW this is in the wrong thread. Try the hybrid swap thread
https://honda-tech.com/forums/hybrid-engine-swaps-18/
Old Jun 27, 2012 | 08:04 AM
Thanks yeah stock b18c
DA6mike2
Jul 29, 2006 04:01 AM
integuy
Mar 2, 2003 06:52 PM
Hondasaurs
Oct 28, 2002 07:48 AM
