cable bushings
Old Jun 26, 2012 | 08:34 AM
paintb91's Avatar
Icon2 cable bushings
I've reached for days now and I kant find a solid answer..there are no bushings on a used set of 5the speed cables but there are no bushings of the cable linkage or the shifter linkage..are there new ones I can buy to put on to the used h22 ones or do the h22 shifter and cables not need some on h22 side..I don't wanna go install this and come to find out I needa wait a week to get shifter side bushings
Old Jun 26, 2012 | 08:40 AM
paintb91's Avatar
Default Re: cable bushings
II have no digital camera to take pictures nor find a reasonable diagram to help explain my problem but if anyone has a decent diagram I will try to explain
Old Jun 26, 2012 | 08:44 AM
paintb91's Avatar
http://www.hondaautomotiveparts.com/...y5=SHIFT+LEVER
Im talking about #28 or #4 #10...idk which or if any...just the bushings that go inside the loop of the cable
Old Jun 26, 2012 | 08:45 AM
hb_guy's Avatar
if you are talking about the bushings that connect to the trans then yes you can get them.. go to corsport.com search shifter bushings.. they make upgraded bushings with cotter pins for like $30-35.. they also have the shifter bushings for the base plate under the center console, they replace the 4 rubber ones and clean up the slop.. good luck hope this helps
edit just saw th diagram... not sure on that one... maybe u can use ur bushing from your f22 shifter?? wortha try... i mean it SHOULD work 100% as long as u can getur f22bushng out
Old Jun 26, 2012 | 08:52 AM
paintb91's Avatar
Thanks butbtw yea they should work but they look like they are separated and spaced out..have a lot of play in them so id rather not reuse them on the h22 cables unless completely necessary..
corsport
Performance
10
Sep 14, 2010 09:48 AM
jdmeeeeeeeeg
Mar 21, 2010 05:48 PM
square_1
Jan 31, 2009 09:26 PM
pitchblacksi
Honda Civic (2006 - 2015)
Apr 9, 2007 03:46 PM
CivicRaping
Jun 8, 2005 08:08 PM
