PA 98 ex coupe gsr
98 coupe ex with gsr swap located in chambersburg pa
text 717 552 three five five five
3900 obo
was kicked on passenger rear quarter panel. it was repaired but you can tell if you look close the body line isn't 100%. Fresh paint and body work, looks 9/10
runs well, couple small issues- passenger door lock isn't same key hole, linkage isn't 100%. trunk has same keyhole but won't unlock with key for some reason.
probably missing some things
type r cams
s2 intake manifold
S2 springs and coil sleeve - stock height
New oem flywheel
New windshield
Inspected
Aligned
Si rims with good tires
New headlights
new water pump
new timing belt
new oil pump
new starter
new front axles
integra rear disc conversion
new rear rotors
new rear pads
new rear bushings
new front rotors
new front wheel bearings
Oem civic si mounts
Obx header
New stage 2 clutch
working AC
3900 obo
type r cams
s2 intake manifold
New oem flywheel
New windshield
Inspected
Aligned
New headlights
new water pump
new timing belt
new oil pump
new starter
new front axles
new rear rotors
new rear pads
new rear bushings
new front rotors
Oem civic si mounts
Obx header
New stage 2 clutch
working AC
