Del Sol Probs
Old Oct 14, 2002 | 06:17 PM
go_noles28's Avatar
Default Del Sol Probs
I am in the market for a 93-95 Del Sol VTEC and I was wondering if there are any things other than just the mechanical things that I should look at. I am aware of the roof leaking problem on some early 90's but is there any other little faults that I should look out for?
Old Oct 14, 2002 | 06:35 PM
jdmsol's Avatar
Default Re: Del Sol Probs (go_noles28)
First off...do you want the sohc or dohc vtec? If dohc then you can write off the 93. Honda started making the B16 in the sol in 1994. As far as problems go, I'd would not even bother with anything except a 95+ Before that the top will leak and make an annoying rattle noise. The trunk will leak before a 95 as well. In 95 Honda added a trunk release and also a low fuel light. No power locks as well and if safety is a concern, dual airbags and ABS. If I had to do it again, I would go with a 95 VTEC (B16) and it has all the creature comforts that will help you get through the day.
Old Oct 14, 2002 | 07:33 PM
buddha429's Avatar
Default Re: Del Sol Probs (jdmsol)
https://honda-tech.com/zerothread?id=305152
man, that's the cleanest del sol i've ever seen... i mean clean like spic-n-span clean... good price too, i wish i was local, i'd take it... l8rz
Old Oct 15, 2002 | 04:44 AM
stevecockrill's Avatar
Entirely depends on what you want to do. Are you interested in doing a swap? Do you plan to keep it stock? Looking for a "race" car (ie, is weight an issue?).......
More input needed......
Steve
sandiaman
Jan 11, 2012 05:49 AM
leroyb
12
Nov 27, 2006 07:44 AM
StockCivicRacer
29
Jun 21, 2004 03:15 AM
