FT: 1990 Toyota 4Runner 4x4 5spd v6
Old Jun 25, 2012 | 01:37 PM
all_motor's Avatar
Default FT: 1990 Toyota 4Runner 4x4 5spd v6
Up for sale/trade is my 1990 Toyota 4Runner 4x4 5spd V6. The truck runs perfectly fine. It is my daily driver with no known mechanical issues. The following were replaced new less than a year ago: timing belt, water pump, igniter, coil, spark plug/wires, distributor cap/rotor, front lower ball joints, valve cover gasket, radiator, battery, wheels, speedometer cable, high flow cat, muffler, clutch and flywheel. I'm sure there are other things I am forgetting, but those are the things that come to mind. The truck is very clean for it's age. AC /heater works! AC blows ice cold, colder than my gf's 2004 Toyota Rav4 and colder than my brothers Nissan Versa. No clutch start button works, rear window works/rolls down. The wheels are Crager Soft 8's mounted on Michelin LTX All Terrain tires. The truck has a clean title.
The bad: the off road lights doesn't work, it's not hooked up (bought it like that), the truck recently started to squeal when it is started (easy fix), the battery light is on in the dash (it came on after I sprayed the engine bay down with water for a cleaning), the brake light is on, the truck will not pass smog, after replacing the cat and muffler, the mechanic said it is more than likely the EGR valve. I threw in the towel and used a bottle of CRC 05063 Guaranteed To Pass Emissions Test Formula I got from Autozone, followed the instructions and I passed with flying colors, the mileage shown on the odometer is not the actual miles, it has 100,000 more. I strongly believe that whoever owned it before I did, did an odometer rollback or the gauge probably crapped out and they replaced the odometer with another one from a parts car or from the junk yard. Paint is faded on some areas of the truck, especially the hood. The truck leaks oil (power steering, line needs to be changed). The truck does not have a sound system. Dash is cracked. Drivers seat is worn out from all these years.
The reason I am selling/trading the truck is because I don't have a job and I can't afford to drive her. The money I get from selling her will be used towards a fuel economy car. The truck has never let me down once. I take her out on fishing/hunting/camping trips. She's been through all kinds of terrain; rocky dirt roads, soft sand, mud. She's been put to use, but not abused. This truck was made for off-roads. As reliable as can be.
I will consider trades for a Honda CRX 88-91. Must be in the same condition as my truck. Must be clean (especially the interior), 5spd, stock, and AC must work! Shoot me with what you have, the worst thing I'll say is no.
** TEXT ONLY** 916-317-6447, and please state you saw the ad from honda-tech. I am located in the IE.
Old Aug 22, 2012 | 01:06 AM
all_motor's Avatar
Default Re: FT: 1990 Toyota 4Runner 4x4 5spd v6
bump.
Old Aug 22, 2012 | 10:52 PM
junior40er's Avatar
I might be interested. I have a 91 crx hf stock minus shocks/spring combo, straight body 5 speed. I average 46-50 MPG.
Ever come to victorville? Maybe I can check it out and you look at the crx.
Old Aug 22, 2012 | 11:36 PM
all_motor's Avatar
PM sent.
Old Aug 23, 2012 | 05:35 AM
ej2man's Avatar
Bump
raymondpowens
Jan 5, 2015 04:13 PM
Fej
Nov 4, 2014 12:16 PM
e30trooper
Jun 22, 2011 12:03 PM
johnnychavo
Apr 25, 2010 08:14 AM
Montx
Feb 27, 2008 09:35 PM
