OBD I conversion help, runs fine with pm6 and td-02
Old Jun 25, 2012 | 03:05 AM
singlecamsaint's Avatar
Default OBD I conversion help, runs fine with pm6 and td-02
hi out there, ive got a 89 std hatch. a6/z6 mini me, that ive been slowly building for about 2 years. shortly after i bought it i did the mpfi swap obd 0 style. ive finally got around to doing the obd I conversion and im stumped. i bought a zerg industries ecu jumper and dizzy jumper and i have a stock p28, so i put it all in yesterday. try to crank it nothing just spins. the dizzy and ecu are both good, as i had already seen both parts in action. problem is that it will not start no matter what. i havent wired in the vtec stuff or the 4 wire o2 sensor, but those being undone shouldnt cause it not to run should it? id really like to sort this out im tired of running around on a sub par ecu and one bolt ghetto rigging my dizzy on. any input is appreciated! thanks
Edit: also the car will fire once or twice but thats all, only codes i can come up with are 19, 21,22,and 41
Old Jun 29, 2012 | 08:11 AM
CRXz6's Avatar
Default Re: OBD I conversion help, runs fine with pm6 and td-02
Pony up the money for a Rywire OBD-1 conversion harness. Did it for my car and it was plug and play.
Old Jun 29, 2012 | 08:12 AM
CRXz6's Avatar
also the mini me swap probably wasn't the best idea either...
Old Jun 29, 2012 | 08:44 AM
HondaPartsHero's Avatar
Technical Hero
Code 19 is for auto transmission. Is your ECU an auto ECU?
Old Jun 29, 2012 | 08:46 AM
Technical Hero
If its definitely a manual ECU are you sure the code isn't 10 & 9
Old Jun 29, 2012 | 04:04 PM
janz3n's Avatar
do you have spark and fuel, should be the first question.
Happy Gilmore
Jun 12, 2008 05:33 AM
prionailurus
Mar 25, 2008 12:28 AM
groundedcivic91
Jan 19, 2005 09:33 PM
91lsteg
Jan 9, 2005 11:43 AM
AB16A2T
Jul 13, 2002 09:02 PM
