Civic dx - what sway bar set up would b good?
so i have a dx coupe that was given to me and was wondering what sway bar set up would b good.
and what other parts would i need to get to make it all work..
front rear.
its all stock suspension
with a lsv swap
front rear.
with a lsv swap
Sway bars are a personal opinion/feel kind of thing. As for the rest of your suspension, check the stickies. There are a couple good threads in there about suspension.
1996-00 civic EX/HX/LX will be easier to find. The other opiton is 99-00 SI, which isn't easy to find, and normally pretty expensive. you could also use a 94-01 integra sway bar.
for the rear. 99-00 SI, 94-01 Integra, 92-95 civic.
that's the jist of it.
If you have a stock suspension I'd encourage you to just get OEM spec swaybars.
Even once you modify/lower/stiffen your suspension the OE bars will still be solid.
You planning on autocross or road racing? Or just want a better feel from your grocery getter?
Indeed. If you're running an all season you're pretty much wasting your time with a good swaybar setup.
Niskyspy
Feb 6, 2008 04:13 PM
No More Civic
Nov 7, 2002 09:13 AM
