2 throttle cables but only one fits
Old Jun 24, 2012 | 07:59 AM
hondaaccordf23's Avatar
Default 2 throttle cables but only one fits
What do I do if I have two throttle cables but only have one spot on the new motor h23 vtec
Also they won't fit tight any suggestion
Old Jun 24, 2012 | 02:07 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: 2 throttle cables but only one fits
One of those throttle cables is going to be for your cruise control. I'm not sure on the H23, but for the H22 you have to ditch the cruise control or swap the throttle bodies for your F series one.
You need the one for your gas pedal for the car to function...
Old Jun 24, 2012 | 05:50 PM
GhostAccord's Avatar
IIRC you keep the short one.
Isn't there an H22 throttle body that has the two mounts for the cruise bracket to mount to? I remember seeing one that didn't have the holes but the two protruding mounting things were still there, just need to be drilled and tapped.
Old Jun 25, 2012 | 07:44 AM
Thanks I figured that was the cruise I'll just ditch it for now
Old Jun 25, 2012 | 07:45 AM
also my gas pedal cable is too long whats your suggestion on that
Old Jun 25, 2012 | 12:20 PM
May need to add an adjustable bracket where the cable mounts to the front of the intake manifold. I have one around here somewhere. I'll see if I can find it so you can see what I'm talking about. Highly doubt that I'll be using it any more.
Old Jun 25, 2012 | 02:22 PM
that would be cool thanks
Posted from Honda-tech.com App for Android
everythingwentblack
Nov 19, 2010 10:47 AM
snowblind7x
Feb 8, 2006 11:30 AM
Jonathan_ED3
Oct 4, 2005 12:09 PM
Bruce_Willis
Dec 9, 2004 10:33 AM
