y5 block, y8 head ecu question
Old Jun 23, 2012 | 10:54 PM
pwnsauce ek's Avatar
Default y5 block, y8 head ecu question
hello all.
im new here but have been lurking for a long time.
anyways i just bought a 99 dx hatch. it has a d16y5 swap with a y8 head in it and vtec is not hooked up. it has a p2e ecu in it.
i also have a 2000 ex coupe with d16y8 stock ecu but has a spun rod bearing.
my question is can i just use the ecu from my ex in my hatch? and run wires for vtec. or does the hx block change things?
btw both are 5 speed
Old Jun 24, 2012 | 04:24 AM
Former User's Avatar
Default Re: y5 block, y8 head ecu question
Yes, I think you can use the P2P ECU from the 00 Civic EX, but what engine wire harness does the 99 DX hatch have?
Old Jun 24, 2012 | 10:49 AM
94preludeguy's Avatar
D16Y5/7/8 blocks are identical. Only differences are oil pans and if I remember correctly the girdles might be a little different. Since both cars are OBD2B you can use the ECU out of your 00.
Old Jun 24, 2012 | 10:50 AM
jbpnoman's Avatar
Originally Posted by 94preludeguy
D16Y5/7/8 blocks are identical. Only differences are oil pans and if I remember correctly the girdles might be a little different. Since both cars are OBD2A you can use the ECU out of your 00.
What preludeguy means is OBD2B. 96-98 = OBD2A, 99-00 = OBD2B.
Old Jun 24, 2012 | 10:59 AM
Whoops yeah good catch. My old EK has a 96 so I just got used to always saying OBD2A but yes he is correct it's actually 2B.
Old Jun 24, 2012 | 12:40 PM
Awesome. Thanks guys.
Im sure i could find it if i looked but anyone know of a diy or something for running vtec wires?
Also im pretty sure its a y7 harness still. Theres a few unused connectors hangin in the engine bay.
And i read somewhere the y8 knock sensor is diferent. Any clarification?
Old Jun 24, 2012 | 12:55 PM
Post clear pictures of the free connectors and show their wire colors.
Old Jun 24, 2012 | 02:18 PM
Use those schematics for your wiring. As far as a how-to on the VTEC wiring I'm pretty sure you can use this for guidance, just use the OBD2B pinouts instead.
So just follow the steps but the pinouts (ex A14) may be different on OBD2B. Sorry, couldn't find a DIY like this just for OBD2B.
EDIT: Whoops looks like that second diagram is for B-Series. Basically A8 is vtec solenoid, C15 is the pressure switch, D6 knock sensor..
Old Jun 24, 2012 | 03:00 PM
HondaPartsHero's Avatar
Technical Hero
Also the Y5 doesn't have a knock sensor so snag that from the EX as well
Old Jun 24, 2012 | 05:17 PM
well i switched the ecu's and started it. idle was kinda bouncing and idling high. now i know why. the only cel i had was iacv, vtec pressure sensor or something like that, and secondary o2 heater circuit (which i already had before switching ecu)
but since i have to get the knock sensor off my ex ill just wait and do the knock sensor vtec wires iacv and swap intake manifolds all at once instead. anyone have a guesstimate how long of a job that is? ive yet to remove an intake manifold but ive heard its a pita.
but heres those pics
i just realized thats the oil pressure sensor but thats one i was talking about
and this one was just laying on the tranny.
as for the wire colors they all look black cuz their really dirty but i think their -
yellow/black
green/red
blue/green
black/white
again those could be wrong though
Old Jun 24, 2012 | 06:13 PM
oh and according to my chiltons manual the 99-00 d16y5 does have a knock sensor.
Old Jun 24, 2012 | 06:19 PM
yellow/black
green/red
blue/green
black/white
For the information to be of any use, you must reliably match wire colors to connectors shown in the pictures.
Old Jun 24, 2012 | 06:59 PM
ok i pulled the loom back some and its
white/red
green/black
black/white
black/yellow
Old Jun 25, 2012 | 01:34 AM
Technical Hero
First pic VTEC solenoid
Second pic is for the secondary 02 sensor
The two sensors you have codes for. Probably because whoever did the swap didn't extend the 2nd 02 to the position after the catalytic converter. Do you have a cat on the car? Also they probably didn't hook up VTEC to the ECU. Also looking at your first sensor pic the VTEC pressure switch has no wires coming out of it. You'll have to run wiring for both those sensors for VTEC to work. You also probably don't have the IACV wired to two wire as for why you have that code. Take some pics of the intake manifold area around the throttle body and I can confirm. Here's the wiring you'll have to do along withe knock sensor:
Chris0619
Dec 1, 2013 04:15 PM
Bakado
Feb 17, 2012 03:43 PM
MatakiRotorD16
Jan 20, 2011 12:45 PM
hipochevys
Nov 16, 2004 06:00 PM
Civiclx
Aug 1, 2003 06:24 PM
