Del Sol Driver window won't roll down! HELP Please!!!
Old Jun 23, 2012 | 09:27 PM
Ju1cesk8er's Avatar
Default Del Sol Driver window won't roll down! HELP Please!!!
I just got a new door and the owner said that the power windows work perfectly. My last door didn't have a regulator on it. I installed this door and the power windows is still not working. Its just the driverside. All other sides work perfectly. What could it be? Could it be faulty wiring? Theres a bunch of wires hanging from near the interior fusebox. Please help me!! This is sooo annoying!!!
Old Jun 23, 2012 | 09:34 PM
DCAR's Avatar
Default Re: Del Sol Driver window won't roll down! HELP Please!!!
did you keep your same door panel and switches on the panel? maybe it would be a bad door switch.?
Old Jun 23, 2012 | 09:36 PM
Ju1cesk8er's Avatar
I tried switching them and still no luck... I just hear a clicking noise from behind the radio.
Old Jun 24, 2012 | 04:30 AM
Former User's Avatar
What year Del Sol?
Post pictures of the hanging wires.
Next test the window motor in the driver's door by running power and ground wires to it directly from the battery. Up versus down is controlled by switching polarity of the wires. Does the motor run?
Old Jun 25, 2012 | 11:21 AM
Ju1cesk8er's Avatar
I am very bad with electrical things. Can I use any wire? I will try so now. Its a 1994. Here is the pic. Sorry for the huge pic..
Old Jun 25, 2012 | 11:22 AM
grumblemarc's Avatar
The Grumpiest
Oboy.
Old Jun 25, 2012 | 11:37 AM
Ju1cesk8er's Avatar
Should I take another? I don't know why it posted so big....
Old Jun 25, 2012 | 11:43 AM
The Grumpiest
No. I'm commenting on that rat's nest. Why are the wires in that condition? Did you buy it like that?
In the meantime follow the steps outlined in pot #4. Any wire should work.
Old Jun 25, 2012 | 11:54 AM
Picture size reduced.
Wire nightmare.
Run wires directly from the battery posts.
Old Jun 25, 2012 | 12:16 PM
Ju1cesk8er's Avatar
Yeah when I bought it they were all hanging like so. Okay I'm gonna get to it now and post the after-math. Thanks. I really do appreciate it.
Old Jul 2, 2012 | 02:26 PM
Ju1cesk8er's Avatar
You guys know where I can get some wire?
Old Jul 2, 2012 | 02:31 PM
schpiel's Avatar
You need to do this right the first time. That kind of mess will leave you puzzled forever. I can tell you through my experience on these things, that you need to do what the man suggested in post 4 before anything else. Once you have established that the motor is good...you better pull back the rubber seal where your fender harness meets your door. There is a high possibility you will find some broken wires.
Old Jul 2, 2012 | 02:57 PM
Ju1cesk8er's Avatar
I'm trying to test the motor now but I dont have any long enough wire.
Old Jul 27, 2012 | 02:29 PM
Ju1cesk8er's Avatar
I'm trying to test the window motor now. I really don't think I'm doing this right. Help!?
How am I supposed to get the wires in there? Are they suppose to go in there?
Old Aug 10, 2012 | 07:31 PM
Ju1cesk8er's Avatar
BUMP*
Please help!!
I need this window down. Its hot as all hell where I live.
Old Aug 11, 2012 | 04:00 PM
JC_1118's Avatar
I had a similar issue, for a quick fixypu can run a wire to your fuse box, and then to the plug for the door switch. This should get them to go up and down. My problem ended up being a few thing: a cut wire which needed to be soldered, I replaced the fuse box, and all fuses, next was replace the connector into the door. After doing all that power works great.
Old Aug 12, 2012 | 10:43 AM
Ju1cesk8er's Avatar
Thanks for the response!!
The thing is I suck at electrical stuff so I wouldn't even know where to start on that.
Old Aug 13, 2012 | 04:32 AM
JC_1118's Avatar
Don't worry man, so do I. Just get a wire long enough to go from your door to your fuse box under dash. Something that is not too thick, in your fuse box you should have a few empty place that would hold relays, touch one end of the wire to that, and place the other into the connector on the door. The connector has multiple wires, so you'll have to try each one.
Old Aug 13, 2012 | 04:13 PM
Ju1cesk8er's Avatar
Okay I'm gonna go give it a shot now.
kinseljr
Dec 26, 2017 02:30 AM
Dustinninja
Jan 3, 2017 09:16 PM
JC_1118
Jul 5, 2012 11:01 AM
Ju1cesk8er
Jun 10, 2012 02:02 PM
SolTrane
14
Sep 26, 2006 06:05 PM
