Cracked Radiator going over speed bump
Old Jun 23, 2012 | 06:02 PM
b20bFourDoorCivicLX's Avatar
Default Cracked Radiator going over speed bump
this is how low my car is, i went over the speed bump and then bam all of a sudden im seeing a trail of antifreeze, i get home and find where its coming from directly under my radiator, is it possiable i cracked it from being so low, or was this under pressure? wouldnt my hoses been the first to go? well i go on monday to get it fixed but i still have places to go like tomorrow not to far, and monday to work and then rigght after to get it fixed, is it safe to drive my car for short periods of time
Old Jun 23, 2012 | 06:07 PM
1998GsRIntegra's Avatar
Default Re: Cracked Radiator going over speed bump
Was probably old/fatigued and the bump just exploited a crack that was already semi there. I wouldn't drive it. It will overheat pretty quick with out coolant and your fan would just burn itself out constantly running to try to cool down coolant that isn't there. Call a taxi, walk, ride a bike, or take the bus if you have to be places.
EDIT: Btw, is your front wheel really fu*king bent or is that just the picture?
Old Jun 23, 2012 | 06:16 PM
yea its really f*kin bent, its on my to-do list, im trying to find a spot where i can get it fixed..cheap...all the rest are mint rims or i would just get rid of them,
i almost dont want to drive it, ****
i just am confused when it started leaking today because i was getting on it going up a hill. and then finally arrived to my destination i was waiting to park so i backed up a little noticing a small trail of leaking anti-freeze ...right before that i hit a large speed bump that made a ugly scratch noise. ive done it before, so it just confuses me that today my **** starts to leak, but like i asked, if it was a bad water pump wouldnt my hoses exploded ...cuz my car wasnt over heatin....
Old Jun 23, 2012 | 06:24 PM
If your water pump went out your car would just over heat and eventually the rad cap would release coolant into the overflow tank and it would boil over. I can't think of any situation that would cause your coolant hoses to explode other than maybe a welded shut radiator and a broken water pump. The coolant would expand and look for the easiest way out of the system which would then be the coolant hoses because the overflow tank would be taken out of the equation.
Old Jun 23, 2012 | 06:54 PM
alright, well i think im good on my waterpump. 35 dollers to remove my radiator/flush and weld the crack, i almost want to buy some j-b weld
now im really not going over speed bumps no more.
you kno what i hate, when im trying to crawl over the bumps or dips i get tail-gated."cars get all on my ***" and im a defensive driver i almost get offended....i didnt "slam" my car either its at a decent height and handles really good
Old Jun 23, 2012 | 07:19 PM
Mine scrapes everything because it was low to begin with and after I put the special projects motorsports splitter on the deal was pretty much sealed. I setup my rear wiper fluid sprayer to spray cars behind me that tailgate. Pretty entertaining to watch. I go sideways and crawl over speed bumps.
Old Jun 23, 2012 | 07:28 PM
ROFL , i applaud you .. i most of the time go at an angle,,but with no p.s it makes it difficult and i feel like a moron with cars staring at me like wtf lmao , IM Just going to avoid parking lot speed bumps...those are usually the big ones....
artie89
Oct 20, 2013 11:51 AM
airric
Nov 23, 2010 11:24 AM
97RSTEG
Jul 21, 2006 03:38 PM
crazykid9137
Oct 4, 2005 06:46 PM
C2Imports
Feb 18, 2005 01:11 PM
