93 civic coupe part out k swapped turbo nitrous
Parting out a 1993 civic coupe ex
Frost white. Was originally an auto chassis but had a k24/k20 under the hood performed in 2007-2008. The chassis isn't for sale as it has had some irreparable damage performed as a result of the swap (cut out trans mount, floor cut out for shifter box, rad support hacked up for fmic and damage as a result of a crash pre-swap)
Car is heavily modified. Incomplete list of what's available:
-oem left passenger headlight $40
-integra rs rear disc, sway, 40/40 prop $150
-NOS nitrous oxide system nitrous setup $350
-FMIC " XS POWER" pretty thick core, decent GTAW welds, all alum, cast end tanks $200
-first gen hybrid racing all aluminum k swap mounts eg/dc $300
-k24a1/ crv timing side mount (needed to clear taller deck height) $25
-crv short block with arp head studs, rsx oil pump etc. $850
-carbon creations carbon fiber hood $175
-grey optional audio console/ "jdm center console"
-auto window doors frost white. $50 ea.
-reproduction oe style factory primed fenders both sides $40 ea.
-oem tail lights $35
-oem trunk no tail lights $45
- auto to 5 speed pedal setup, clutch master cylinder and all associated hardware $150
-various tan and grey interior pieces From $5
- unused d series 92-95 civic, non ABS Auto or manual i think $25 set
Also selling a d16z6 long block from the civic will include a bill of sale and copy of the pink slip (clean) when buying the motor. Head work done in 2007 by a local machine shop, 3 angle valve job, hot tanked and rebuilt. Rings are beckarnely life time warranty. It sat since 2007 id go through it again. $350
Prices are NOT firm, send me a PM and i'll work with you.
Located in temecula-murrieta area.
92562-92592
If you need parts shipped, don't hesitate to ask I'll do it via usps priority flat rate.
92562-92592
ninethree-civic
Dec 10, 2008 10:04 AM
nutty562
Jan 19, 2008 04:55 PM
