Changed spark plugs today - Oil on Plugs ?
Old Jun 23, 2012 | 02:27 PM
Rob.'s Avatar
Icon2 Changed spark plugs today - Oil on Plugs ?
Well it was about that time to change the spark plugs on my CRX D16a6.
Anyways, when I took out the plugs, I noticed some oil has gotten the plug on on cylinder 4 and a bit on cyl 3. Btw, seems only 1 electrode is oily.
The valve cover gaskets are 4 years old. I did check for tightness of the valve cover and it seemed a bit loose.
Could this be a symptom of worn bores/piston rings or valve guides ?
My CRX has 265,000 km (164,663 miles)
Also, I bought the NGK BCPR7E-11 plugs which run 1 step cooler.
Some pics:
OLD VS NEW
Old Jun 23, 2012 | 11:58 PM
Scott91Hatch's Avatar
Default Re: Changed spark plugs today - Oil on Plugs ?
this may help
http://www.tegger.com/hondafaq/oilyplugs/index.html
Old Jun 24, 2012 | 08:29 AM
Rob.'s Avatar
This is a great video on this matter:
http://www.youtube.com/watch?v=wYU8qtPzQOY
Old Jun 24, 2012 | 03:25 PM
rapom's Avatar
I had the same problem, turned out to be the O-rings under the rocker assembly. Major PITA if you ask me, so I just let it go, but if you have a well equipped garage it should only take 45 min or so to change em.
Old Jun 27, 2012 | 10:13 AM
Rob.'s Avatar
Today I went to Honda and exchanged the colder plugs (BCPR7E-11) to the normal plugs (BCPR6E-11). They took them back even though I had installed them.
They even installed and torqued down (13lbs) the new plugs for me, free of charge
Old Jun 27, 2012 | 12:08 PM
4drEF's Avatar
Keyboard Humorist
Valve stem seals?
LAO
Dec 14, 2007 07:36 PM
Mr.Speed
10
Jun 18, 2005 06:15 PM
Integgedout
Jul 26, 2004 08:24 PM
7rrivera7
Dec 21, 2003 03:47 PM
dohc_Cx
Aug 28, 2001 11:33 AM
