Which axle should i use for f22a1 in 5th gen accord
Old Jun 23, 2012 | 11:47 AM
Delta3619's Avatar
Default Which axle should i use for f22a1 in 5th gen accord
As the title say, i swapped a f22a1 from 92 accord in my 94 accord but the axles seems to have loose. I searched on google and all i found is that:
Axles Use 90 up Accord Intermediate shaft with 90-93 Integra axles.
To use the Prelude intermediate shaft a shorter left-hand axle with a female inner joint must be used. To construct the proper left-hand axle use 94 GSR left-hand axle inner and outer joints on an 86-89 Integra axleshaft.
Can someone confirm it or tell me which axle will fit with this swap?
Old Jun 23, 2012 | 12:46 PM
GhostAccord's Avatar
Default Re: Which axle should i use for f22a1 in 5th gen accord
Question is what transmission are you using, CB or CD?
Old Jun 23, 2012 | 01:23 PM
Delta3619's Avatar
I'm not sure what CB and CD are, but i have the transmission that was in the 92 accord (f22a1).
the passenger side axle seem to fit well, without loose, but i'm not an expert so i can't say if it really fit.
Old Jun 23, 2012 | 02:49 PM
The CB & CD initials are the vehicles chassis code. CB = 90-93 Accords. CD = 94-97 Accords
Here is a complete list of what is required for a 5sp swap.
http://www.accordinglydone.com/forum...ead.php?t=9624
According to it you should be using the axles and intermediate shaft from a 94-97 5spd Accord.
Old Jun 23, 2012 | 03:33 PM
Delta3619's Avatar
Thank you for the answer, according to yhe informations, i got a CD chassis. So i have to use whole axle from my accord 94?
Last question, would my transmission fit from a f22b2 (Dont know the number for this tranny) to my f22a1?
Old Jun 23, 2012 | 03:48 PM
Yes the F22A and F22B transmissions are interchangeable. Along with H22 and H23 transmissions as well.
What is the transmission number on the F22A 5 spd? It is located on the bell housing on the bar code sticker.
Old Jun 23, 2012 | 04:07 PM
Thepowderblue's Avatar
Use the axles made for your car
Old Jun 24, 2012 | 04:12 PM
Delta3619's Avatar
Thank for the answers, i'll put the axle tommorow and will feed back
Old Jun 25, 2012 | 03:24 PM
Delta3619's Avatar
The 94 accord axles seems too long for now and i am unable to find any spec about axles lenght :S
Old Jun 25, 2012 | 05:48 PM
Delta3619's Avatar
Ok my bad... The 94 axle fit just fine Thank a lot for the answers
Old Jun 25, 2012 | 05:58 PM
AZAccord712's Avatar
I have a question of my own. Will a f23a fit into a 1993 Honda Accord EX I am still new to the honda scene. I tried to do my research online I didnt come up with anything.
Old Jun 25, 2012 | 06:41 PM
accordin 2 me's Avatar
yes!
lowlowloweg6
Jan 7, 2016 04:12 AM
Daniel san
Jun 5, 2005 06:53 PM
B18CUL8R
Jun 5, 2004 03:10 PM
ACRProject
Mar 15, 2004 07:59 AM
