looking for a good D series motor to put in a classic mini
Old Jun 23, 2012 | 09:33 AM
xxredxpandaxx's Avatar
Default looking for a good D series motor to put in a classic mini
I am looking for a D series motor that I can pretty easily get 200hp (or over) with. Also I would like to still get about 30mpg highway.
Old Jun 23, 2012 | 09:51 AM
grumblemarc's Avatar
The Grumpiest
Default Re: looking for a good D series motor
No such engine exists.
Old Jun 23, 2012 | 10:14 AM
EJ8_Man's Avatar
failed first post
Old Jun 23, 2012 | 10:48 AM
The motor is going in a classic mini which only weighs around 1500 lbs with the motor. If I was to just add a turbo what kind of power would I be looking at with say a d16z6 or z7?
Old Jun 23, 2012 | 10:54 AM
Jimmy's Avatar
Global Moderator
Depends on the turbo setup and engine management. Could vary greatly. I would say 200-215 whp would be fun in a little car like that though.
Check out the Forced induction forum and start doing some research.. lots of information out there!
Old Jun 23, 2012 | 10:56 AM
The Grumpiest
D-series can safely boost 200ish hp on a stock block. YOu won't ever get 200hp in N/A form.
Old Jun 23, 2012 | 11:17 AM
Any specific turbo kits you would suggest? and I saw one guy who had one that had about 195bhp I think and he said it did 0-60 in 3 seconds. Not sure if it was all-wheel drive or not though. I also need to see if a turbo would fit on it while in that car.
Im planning on getting a turbo for it.
Old Jun 23, 2012 | 11:24 AM
The Grumpiest
Good for you. make sure the engine is healthy and you get good parts for the build.
Old Jun 23, 2012 | 11:33 AM
Edgar19q's Avatar
D17 would be a good choice my buddy had one..
He had a tune he only knows not sure how he did it but he was
Pushing over 200
Old Jun 23, 2012 | 11:34 AM
I was thinking about getting one from JDM because they are suppose to be pretty good. And I will be sure to get quality parts!
Old Jun 23, 2012 | 11:35 AM
Pushing over 200
Any idea how much d17's go for?
Old Jun 23, 2012 | 11:43 AM
The Grumpiest
Getting one from where?
Old Jun 23, 2012 | 11:47 AM
http://www.jdmenginedepot.com/ They get engines from japan that have around 50,000 miles on them and because they are much more strickt over there they bring them here.
Old Jun 23, 2012 | 12:01 PM
I just read somewhere that with 200hp an automatic transmission would not hold up. Is this true?
Old Jun 23, 2012 | 12:23 PM
redm3turbo's Avatar
^ why would you want a auto?
Old Jun 23, 2012 | 12:31 PM
No a big fan of driving a stick.
Old Jun 23, 2012 | 12:41 PM
redm3turbo's Avatar
Id erase that last comment, that wont go over well around these parts,lol.
Old Jun 23, 2012 | 12:43 PM
redm3turbo's Avatar
and honestly I dont think a stock honda d series trans would hold 200 hp, the trans on these motors are very weak spots to being with.
that coupled with 200 hp from a d series = boost.
boost + automatic = not great
Old Jun 23, 2012 | 01:09 PM
Red-Rocket's Avatar
get a DOHC ZC (~130 hp), stage 2 clutch, and piece together a good turbo setup, and most importantly GET IT TUNED!!!
Old Jun 23, 2012 | 01:41 PM
The Grumpiest
I've never heard that before. These transmissions are actually pretty strong. I think you were just talking autos in particular.
Old Jun 23, 2012 | 01:57 PM
Well I can't go with just any motor, I have to make sure it will fit in the mini. I know a d16z6 fits so I think im just going to go with that. And if the trany ends up breaking I might swap it out with a stick if they really are stronger. Also will a super charger get me to 200hp? Im not sure if a turbo will fit I, will have to see.
Old Jun 23, 2012 | 02:01 PM
The Grumpiest
Don't bother with a DOHC ZC. Another overrated engine. Two cams and still only 130hp? BTW, "Stage 2 clutch" doesn't mean anything.
I also wouldn't touch a D17 for modding. The tuning solution you pick better be able to deal with a COP engine, which is pricy. For what you have to do to get a D17 in your car you might as well drop a K series in it. If' its going in a Mini then you have no choice.
Stick with a Z6 or a Y8.
And if you're sticking with an automatic you might as well get a JRSC and call it a day. Automatics made by Honda don't hold power worth beans and D-series can only hold 200hp stock if the engine is healthy. People need to start doing some reading prior to posting.
You can fit anything in a mini. The shop I go to put a K in one of the older ones.
If this isn't going into a Civic then you need to look in the Hybrid forums.
Sounds like you have no idea what you're going to do. IMO putting an automatic D-series in a Mini and trying to boost it is just retarded.
Old Jun 23, 2012 | 02:12 PM
Hidenplanvew's Avatar
I heard a while ago something about a Z6 head on a D17 but it was a few years ago.. I don't know if they ever got it to run.. I know you can make a "D18"... Z6 block, D17 crank, d17 rods, bore, Custom pistons.. You have to turn the stub of the d17 crank down to fit the Z6 block. It was a pretty cool set up and made pretty good power.
Old Jun 23, 2012 | 02:13 PM
Its going in a mini and they sell subframes for D, B, and K series but some engines fit better than others. With some you have to make it a flip front because it wont set in properly. With the d16z6 you don't have to do very much to make it fit that is one of the reasons I am going with that engine. Im going D because I don't need much power and they are cheaper.
