98 Civic front wheel has some side to side play -- bearing? or is it.
Old Jun 23, 2012 | 08:07 AM
SiRCiviC94's Avatar
Default 98 Civic front wheel has some side to side play -- bearing? or is it.
jack up car wheel wobbles side to side ( a little play) but not if I put my hands at 12 and 6 (wobble back and fourth)
98 civic hb with gsr
i replaced the axles and tightened the 32mm nut tight im jw if it could be a ball joint or something else? or to worry about that. i hear nothing feel nothing driving
Old Jun 23, 2012 | 08:12 AM
grumblemarc's Avatar
The Grumpiest
Default Re: front wheel bearing? or is it.
Tie rods or ball joints.
Old Jun 23, 2012 | 11:24 AM
SiRCiviC94's Avatar
might be tie rod then, the ball joint seemed great when i popped it off for the axle. everything seemed tight actually so idk. and im too lazy to mess with the LCA maybe later lol
thx!
Old Jun 23, 2012 | 12:52 PM
redm3turbo's Avatar
3 and 9 on the wheel, as far as I Remeber is outer tie rod...or just tie rod in general.
lifting up on the tire or pressing 12 / 6 is balljoint...
and make sure your lugs are a good 80lbs.
I spent all day once trying to diagnose a sound....turned out some jerkoff loosened my lugnuts. It was the last thing I looked at since I had torqued them down 3 days prior and never thought they'd back themselves off....
Old Jun 23, 2012 | 04:39 PM
jbpnoman's Avatar
As has already been said, 3/9 wobble is tie rods, tie rod ends, or (worst case) steering rack. The best way to be sure would be to get under the car where you can see those parts, and have a friend either wiggle the wheel, or wiggle the steering wheel so you can see what is moving and how much it's moving.
Old Jun 24, 2012 | 06:34 AM
SiRCiviC94's Avatar
Default Re: 98 Civic front wheel has some side to side play -- bearing? or is it.
thanks so much! I will look into it more before I put it on the road. I always forget hondas are a lower tq on the lugs I put mine at 100ft lbs but use an extension... so say 90-95lbft. that bad? bc they come off tooooooo easy with the iron on anything less.
unfortunatley I still have quite a list for this car to be where I want it kickin *** looking good running perfect. one day tho!
keep in mind if you have 3-9 / 12-6 play you certainly could be looking at a bearing AND ball joints. my old ek I had play all around I tightened the axle it had only 3-9 play, replaced the bearing and it was good to go.
which now gives me a feeling its the bearing. will find out and update.
Old Jun 24, 2012 | 06:54 AM
94EG8's Avatar
Seagull Management
IIRC torque for Honda lugnuts is 80ft lbs for alloy wheels and 90ft lbs for steel wheels. We had preset torque wrenches for them when I worked for Honda. Generally we'd crank the lugnuts on with an impact at something well above what they were supposed to be at and then check with the torque wrench. (it's surprising how often one isn't anywhere near tight enough)
sunny4twenty
Dec 14, 2016 05:10 PM
jonyi27
Dec 9, 2012 10:55 AM
boost4life1
Nov 17, 2011 02:53 PM
tundra2000
May 27, 2011 09:17 AM
Secret Chimp
Feb 20, 2008 06:09 PM
