JDM HID headlight help ASAP
Well I finaly fot my ITR last night
as happy as i was to own one finaly it became bitter sweet on the way home. THe car has a JDM HID front end but the HID ballast or black box is not there. I have not realy got a chance to look to see how it was wired up and what they used for a bulb but it looks great but is super super week out put.
What i want to know is if I can just buy a Phillips HID kit for the USDM ITR headlights and just plug that into the JDM housing port and be done with it or do i need a special set up?
Last night at 1am driving home from sellers house was a nightmare I had the fogs and driving lights on and it was a dim as a **** could not barel see so I need a solution asap cause its scary to drive at night with such low visiblity long range ( 3+ car lenghs). Im gonna play with adjustment on beam to see if helps in the mean time but I need more juice for sure.
YES YES I did a search and found lots of info on teamintegra.net and on HT and thats how I found out i have the HID lights just no HID's but never got the answer im searching for.
as happy as i was to own one finaly it became bitter sweet on the way home. THe car has a JDM HID front end but the HID ballast or black box is not there. I have not realy got a chance to look to see how it was wired up and what they used for a bulb but it looks great but is super super week out put.What i want to know is if I can just buy a Phillips HID kit for the USDM ITR headlights and just plug that into the JDM housing port and be done with it or do i need a special set up?
Why not buy the black box with stock light? I'm sure jdm import shops might have them for reasonable price. I have the jdm hid front and it shines perfect.
I will try my stock bulb in my spare jdm headlight , I'll let you know how it fits in few mins.
Update:
As you can see a stock bulb fits, so you can make a Hid kit bulb fit, I however recommend try to bring her back to stock.
Update:
I would love to buy a ballast OEM set up for my lights but since they r becoming harder to find most shops will not part with them & wont sell them without u buying the whole headlight assembly. So I figure if I can get a Phillips set up for teh USDM ITR for $100 why pay 4x's that for OEM and not get much more for my money.
Then only ? I have now when ordering this kit is they have a options like do u need a relay kit and etc what set up would be best and what options do i need to be as plug and play as possible http://www.philipshidkits.com/acura-integra-hid/
Thanks
-Chris
Thanks
-Chris
Alot of people will recommend to run relays, I do not have relays on any of my cars (with HID kits) or ever had them, If you want to be on the safe side then run them. And I never had a problem.
How dose you wiring look? Do you have stock light bulb plug or is it wired up some how?
I have a set of JDM HID headlights on my R and I want to get rid of the OEM ballasts, bulbs, and the projectors itself because I'm planning on retrofitting it so I'll get a proper LHD cutoffs and more light output with the projector clear lenses upgrade.
CIVIC dude
Mar 1, 2003 11:57 AM
