CTR rear sway bar vs ITR
Old Jun 21, 2012 | 08:36 PM
Kennyjai's Avatar
Default CTR rear sway bar vs ITR
Is there any difference between the CTR and USDM ITR rear sway bar? I know they are the same diameter, both 22mm. But will they need different endlinks or bushings to fit an integra?
Old Jun 21, 2012 | 09:36 PM
YellowKahuna's Avatar
Default Re: CTR rear sway bar vs ITR
Just put the ITR sway bar on the ITR. Call it a day.
Old Jun 21, 2012 | 10:06 PM
Kennyjai's Avatar
do you know where i can find one for cheap? i cant find any atm. also, do we REALLY need a subframe brace to prevent tear out?
Old Jun 21, 2012 | 10:26 PM
doood's Avatar
been there done that
judging from the car in your signature, yes you'll need a reinforcement kit of some sort.
Old Jun 22, 2012 | 06:49 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
If it's a non-ITR and you're actually using the bar for it's purposes, you need a subframe brace. Even if you're doing this for show, use a subframe brace. Ripping out a subframe sounds pretty awful.
The difference between an ITR and CTR bar is the eyelets for the links are smaller on the CTR bar. What does that mean? Nothing if the bar comes with the endlink bushings.
Old Jun 22, 2012 | 09:36 AM
Todd00's Avatar
I said I don't want a title!
A quick search would show you that putting a 22mm rear swaybar on a normal Integra chassis will cause subframe issues.
BTW--wrong forum.
adriano7910
Suspension & Brakes
Feb 20, 2014 04:59 AM
saveacivic
Suspension & Brakes
Apr 15, 2006 12:31 AM
hazard_one
Jan 7, 2004 10:43 AM
