Greddy + Hondata Dyno -- Finally I am Done!!!
Old Oct 14, 2002 | 04:24 PM
DeepSi's Avatar
Default Greddy + Hondata Dyno -- Finally I am Done!!!
Finally i have finished everything and she is running strong. Here are my dynos. Any suggestions or comments welcomed.
Blue: Basemap provided by SGT, when i got the Hondata.
Red: Basemap provided by VaporTrails
Green: Final tuned map
The numbers throughout the rpm spectrum.
If you have any questions just ask.
Application
2000 Civic Si
Greddy Si Turbo Kit
Walbro fuel pump
440ccs
Hondata 3b.
Stock Cat
@5 psi
-deepsi
[Modified by DeepSi, 5:25 PM 10/14/2002]
Old Oct 14, 2002 | 04:29 PM
FBP Si 2000's Avatar
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (DeepSi)
I need to get a baseline dyno done. Hopefully soon...still running the blue box though. Hondata is just sitting there looking pretty.
Turning up the boost anytime soon?
Old Oct 14, 2002 | 04:31 PM
SIK IN DA HED's Avatar
New User
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (FBP Si 2000)
you will NEVER be done. just wait... youll see.
Old Oct 14, 2002 | 04:34 PM
DeepSi's Avatar
My next upgrade is to install my Carsound Cat. I have been told that is why i am only allowed to boost 5psi, because of the exhaust backup caused by the stock cat. I will turn up the boost later. i want to get used to 5 psi right now, and when the boost bug bites again then i will up it again and get it tuned.
Old Oct 14, 2002 | 04:35 PM
DeepSi's Avatar
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (dlplayboy)
I know i already have my next $1000 already laid out and spent
Old Oct 14, 2002 | 04:38 PM
HybridKOOP's Avatar
Tell me this is a "Mustang Dyno"...
Old Oct 14, 2002 | 04:40 PM
DeepSi's Avatar
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (HybridKOOP)
I know it is not high, but remember it is only 5psi. I could not boost higher than that.
Is it true, with the Stock Cat the Greddy Kit can not boost over 5psi, i was told that and it made sense to me. It causes to much exhaust backup, not allowing over 5psi.
-deepsi
Old Oct 14, 2002 | 04:43 PM
dmotoguy's Avatar
-deepsi
how does that make any sense?
Old Oct 14, 2002 | 05:08 PM
Hammett's Avatar
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (dmotoguy)
What size of exhaust piping are you running?
Old Oct 14, 2002 | 05:12 PM
DeepSi's Avatar
Then why is it that the Greddy kit is rated 6.5 psi, but then when an IC is added, 5 psi boost levels can only reached? Most of the people with the Greddy Kits with the IC only boost 5 psi with the Greddy Kit. I use the vaccuum source behind the intake manifold. so it should 6.5 psi even if there is an IC, but it will not go beyond 5psi.
Old Oct 14, 2002 | 05:14 PM
DeepSi's Avatar
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (Hammett)
I have the Greddy SP Exhaust, which is 60mm, but i have a stock Cat.
Old Oct 14, 2002 | 05:15 PM
DIRep972's Avatar
Smarter than you
back pressure in the exhaust system will effect the amount of boost on an internally wastegated car. this is why when u install a downpipe on a supra u hit 15psi from the stock 10 without even touching a boost controller or the wastegate.
those #'s are actually VERY impressive. that torque curve is FLAAAAAAAAAAAAAAAAAAAAAT! cut out that cat and up the boost to 7psi i bet u see 210whp easy. dont forget that a cat causes back pressure and back pressure creates heat, heat causes detonation, detonation blows motors. so by not cutting the cat, u r puting ur motor at risk.
[Modified by DIRep972, 2:16 AM 10/15/2002]
Mr. Softee's Avatar
you should be able to boost 9psi... exhaust back up? wtf? that makes no sense...
Old Oct 14, 2002 | 05:17 PM
DeepSi's Avatar
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (DIRep972)
Thanks DIRep972,
that is exactly what i thought.
Old Oct 14, 2002 | 05:37 PM
Mr. Softee's Avatar
i dont understand why he cant boost more with a MBC...
Old Oct 14, 2002 | 05:49 PM
DIRep972's Avatar
Smarter than you
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (94goldjungsr)
oh he doesnt have one. if he had one he could.
Old Oct 14, 2002 | 05:51 PM
DeepSi's Avatar
So if i had a MBC/EBC i could go beyond 5psi, but how come i could not get the stock 6.5psi?
Is it that the Wastegate is internal, so it does not really measure what is coming from the Intake manifold, and uses what is coming out of the turbo? but when you use a MBC/EBC it uses the measurement coming from the BC? I dont understand why people without the IC can hit 6.5 psi, but once an IC is added boost levels cannot go beyond 5psi.
-deepsi
[Modified by DeepSi, 6:55 PM 10/14/2002]
Old Oct 14, 2002 | 06:11 PM
Midwestrider's Avatar
Congrats on the #'s.
If you don't have a boost controller you have no way of turning up the boost.
There is a guy local to me running the greddy kit on his si w/ a 5zigen exhaust but he hollowed out his cat and w/ a mbc and hondata he was running 10psi w/o issue.
From my understanding w/ the greddy kit the wastegate is internal on the turbo itself. But you can use the actuator arm and adjust it via the screw/nut.
Old Oct 14, 2002 | 06:39 PM
ATgrills.com's Avatar
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (Midwestrider)
I boost up to 11psi all day long with a greddy SOHC kit on my B18b1 with stock CAT....
so I dont know what your talking about!
Tyler
Old Oct 14, 2002 | 06:42 PM
DIRep972's Avatar
Smarter than you
Default Re: Greddy + Hondata Dyno -- Finally I am Done!!! (ATgrills.com)
Tyler
do u have a boost controller?
Old Oct 14, 2002 | 07:59 PM
DeepSi's Avatar
I still dont understand.
How come without an Intercooler the greddy kit provides 6.5 psi?
How come with an Intercooler the greddy kit provides only 5 psi?
Same vacuum source.
Am i right, that with any other turbo kit, the wastegate opens when the x psi is reached, not matter intercooler or not? so shouldn't the greddy kit do the same and have 6.5 with an IC?
this really puzzles me, and i have been doing some real research on this.
Ok so with a boost controller, a greddy kit can be boosted up on the stock cat, but forget the whole stock Cat situation, and can somebody please answer this for me.
thanks in advance.
-deepsi
Old Oct 14, 2002 | 08:04 PM
HybridKOOP's Avatar
To put the icing on the cake, I'm running 8-9psi daily with a stock cat with the GReddy 18G kit on a Civic Si.
EDIT: The reason I asked if it was a Mustang dyno was not to flame you.. but I noticed you made 148 with sGT's basemap, boosted... thats about 8 more hp over stock. Somethings weird.
[Modified by HybridKOOP, 5:05 AM 10/15/2002]
Old Oct 14, 2002 | 08:09 PM
DeepSi's Avatar
Yeah but the basemap was not SGTs i guess i should say, but the basemap provided by Hondata to get the car up and running and to get you to the dyno. I just said basemap by SGT because that is whom i bought the Hondata from.
Old Oct 14, 2002 | 08:31 PM
FredoSP's Avatar
DeepSi, I'll go to Bat for you here ..
First off everyone chill and READ READ READ, he said stock cat. No boost controllers at all.
From how I understand it, there is a pressure drop from the IC, so I think this is why. My boost gauge reads a drop over 5psi and I have a Trust Type 31 IC.
That Dyno looks really good for 5 psi!!
Now as far as turning up the boost, I have seen the nut on the internal wastegate and I really really want to touch it, lol BUT not with this blue box!! I'll have to wait till Hondata comes in my life.
Everyone knocks the GReddy Kit, its not gonna break the world record of anything but its a kick *** kit, just see Arturbo's post of the Install and Ask chris (DIREP..) how smoothly everything went, NO RUNS!!
Im sure with an opened cat you Break 200 HP (EASY)and turning up the boost to say 7 psi. Good job dude
Old Oct 14, 2002 | 09:43 PM
willyboyK20's Avatar
how are your vacumn lines set up from the turbo and wastegate. I ask because on the sohc greddy kits the instructions say to attach a line from the compressor to the port on the wastegate, but by doing that it only reads the boost pressure in the compressor and not real boost pressure going into the engine because of the charge piping and/or intercooler.
It should be from the wg port to a vacumn port on the intake manif.
check this link http://<a href="http://www.turbocivi...ocivic.net</a> its not for a B16 but its the same concept
