FS: Stoptech 2-Piece Aero-Rotor Brake Rotor Parts
Old Jun 21, 2012 | 04:08 PM
nsxtasy's Avatar
H-T Order of Merit
Default FS: Stoptech 2-Piece Aero-Rotor Brake Rotor Parts
***SOLD***
I need to describe what I've got, so bear with me. A while ago, I bought some of Stoptech's brake parts for my Integra Type R, and they shipped me these, which may (or may not) fit other, four-lug Integras or Civics. You're going to need to figure out whether these will work for you and what additional parts you may need.
Definitions: Stoptech makes two-piece Aero-Rotor brake rotors. Each rotor consists of the "hat", the inner section that fits over the lugs; the "friction ring", the outer ring that the caliper clamps the brake pads around; and Inconel fastener hardware that attaches the two, thereby allowing the outer ring to expand with heat without quickly cracking the way one-piece rotors do from track use. The friction ring will eventually crack on the Aero-Rotors too, but in my experience last 2-3 times as many track miles before doing so; once it does, the hat can be re-used after replacing the friction ring. You can read more about the Aero-Rotors on the Stoptech website here. A complete pair of Aero-Rotors typically sells new for $500-600.
What's for sale: All of the following items are included:
1. One complete pair of new Stoptech Aero-Rotors (friction rings and hats, attached with the Stoptech fasteners) with the stock Integra Type R size friction rings (282 mm x 25 mm) but with hats with a 4x100 lug pattern.
2. One pair of new Stoptech friction rings in the same size.
3. One pair of new Inconel fastener hardware kits for attaching the friction rings to the hats.
Will these work for my Integra or Civic which is not a Type R? I don't know. The lug pattern is the same 4x100 used by non-Type R Integras and by older Civics. I don't know what the rotor diameter is for those cars; the thickness of stock Integra rotors is 23 mm for the Type R and 21 mm for other Integras.
Will these work for my Integra Type R? If you are already using Stoptech two-piece Aero-Rotors on your ITR, you can re-use your current hats while mounting these friction rings on them. If you don't already use them, you'll need to buy a pair of Aero-Rotors (using these as replacements after you crack their rings), or you can try to find a pair of hats with the 5x114.3 lug pattern for the Integra Type R (Stoptech part numbers are 37.054.0013 left and 37.054.0014 right).
If you're interested, I also have a pair of used two-piece Aero-Rotors for the NSX on which the friction rings are cracked. I'll throw them in at no additional charge if you would like to see whether you might be able to re-use the hats to fit your ITR. Although the NSX has the same 5x114.3 lug pattern as the ITR, my understanding is that Stoptech uses different part numbers for the hats for the two cars, so they might not fit.
Bottom line: These parts are accurately described but I cannot guarantee whether they will or won't fit any particular car. No refunds if you find they don't fit.
I'll sell all of the above for $200 plus shipping. Local pickup in the Chicago area is available to avoid shipping charges.
Contact me via Private Message or e-mail.
***SOLD***
B2AutoDesigns
47
Jul 24, 2013 03:30 PM
nsxtasy
Jun 21, 2012 04:07 PM
compo1
May 2, 2007 12:15 PM
totaled
Jan 22, 2003 06:04 PM
