92 civic d16z6 misfire
the car has been misfire'ing ever since i got it about a year ago but never really bothered me
it misses in the low rpms only and at idle especially when the ac is on it misses like every couple of seconds.. i did a full tune up fuel filter plugs new dizzy cap rotor
it usually goes away if i change the plugs but it always comes back after a few months..
could it be a bad ecu? bad injectors? oh and i dont get any cel ever
1992 si stock motor and tranny about 220xxx miles.. maby needs a new timing belt?
I think I am having the same issue with mine..
Low compression on that same cylinder I believe that is misfiring, #4. Numbers from #1-3 are about 190-210, and #4 is 150.
Plugs/wires/cap/rotor/igniter/coil are all new.
ok well it seems like it can be a lot of things
bad ecu
bad ground
fuel injectors
piston rings
bad valves
valve adj.
headgasket
ill do a compression test and see watsup
bad ecu
bad ground
fuel injectors
piston rings
bad valves
valve adj.
headgasket
You list a bunch of things you think are "solutions" and try and guess which one it might be.
Last edited by Former User; Jun 21, 2012 at 04:02 PM. Reason: Stop with the personal remarks.
If you think it's any of those things, have your friend test them. Half of them will be confirmed or ruled out by a compression/leakdown test.
I agree it could be a bad plug wire.
If you pulled all the spark plugs and numbered them as to what cylinder they came from and study them visually you might see a slight difference in one or two that might tell you something. If you want, pull them, mark them 1,2,3 &4 with a sharpie on the white ceramic part, take a picture of them side by side and post it in this forum. Give us something to look at. I'm bored.
