FS used all ls-vtec components sold as a set 750.
Old Jun 21, 2012 | 11:59 AM
1fatcrxnem1's Avatar
Default FS used all ls-vtec components sold as a set 750.
putting this up for sale for a week if it doesn't sell most likely will keep it and rebuild it. its and ls vtec set up that was in my car took it out because due to a high rev one of the sleeves cracked so water was coming out of the exhaust(smoke). when i took it out i thought it was the head gasket but turned out it was the number 1 sleeve. car iddled perfectly and ran fine until it warmed u. the it sputtered cuz of the water in that cylinder. everything except the block housing is good. the engine was done about 16k ago.
details.
build was done by power pros.
according to what they said they were putting on.
the head is a b16 head with stage 2 cams portflow valve springs and retainers. 3 angle valve job.(confirmed) i would just have the head inspected before slapping it back on.
the block has itr oil pump. itr pistons. and is suppose to have an ls crank. (haven't opened it so i cant confirm on the lower internals.
all i am going to do if i keep it is get the head inspected. new piston rings, new bearings for the crank/rods. and another ls block.
motor made 205hp on import auto pros dyno. with the set up i had.
only including complete block and head. no manifolds, or distributor, or alternator.
price is 750 firm
if you think buying all the individual components is cheaper than save your comments.
bump it you view please and pm me ur interested. i can text you some pics
currently have a b20 block that i was going to use to rebuild this but i decided to look for an ls block instead. if i have this still when the motor is sold i will include it with the sale.
Old Jun 21, 2012 | 03:14 PM
Default Re: FS used all ls-vtec components sold as a set 750.
Ttt
Old Jun 21, 2012 | 07:20 PM
Ttt
Old Jun 22, 2012 | 06:14 AM
kingofbattle909's Avatar
whatv are you selling?
Old Jun 22, 2012 | 08:07 AM
Lsv components like the title states. Complete head n all block internals
408civic93
19
Mar 18, 2010 11:40 AM
streetdemons
Oct 19, 2009 06:10 AM
champLSinteg
Northern California (Sales)
13
May 1, 2009 03:10 PM
kgibson16
Dec 15, 2005 03:10 PM
onepoint6i
Sep 14, 2005 08:36 PM
