'93 Ignition Cylinder
Old Jun 21, 2012 | 06:03 AM
StreetsideStig's Avatar
Default '93 Ignition Cylinder
Hey Guys,
I'm working on a friend's Accord and we can't get the car to recognize the final "off" position, so the key alarm and dome light stay on, even when the keys are out. It's draining the battery.
I took the white ignition switch off of the back of the cylinder, thinking it wasn't switching over all the way. No dice. I turned it all the way counterclockwise and it's still beeping.
I'm going back over there tonight with some stuff to spray into the key hole. If that doesn't work, do you have any ideas? Which of the wires on the cylinder needs to be disconnected?
Thanks!
Old Jun 21, 2012 | 09:05 PM
PhatAccord92's Avatar
10 Year Member
Default Re: '93 Ignition Cylinder
i would not disconnect any wires. sounds like the ignition lock/ or key tumblers inside are worn out or jammed, causing it not to turn completely
Old Jun 22, 2012 | 01:50 AM
jdmcertified909's Avatar
you dont read threads carefully do you? ok my friend let me tell you what he wrote HE TOOK OFF THE TUMBER LEAVING THE POWER SWITCH INTACT TO THE HARNESS JUST LIKE THE PICTURE BELOW. HE TURNED BACK THE IGNITION SWITCH ALL THE WAY BACK AS IF HE WAS TURNING THE CAR OFF AND IT WAS STILL BEEPING SAYING KEY WAS IN THE IGNITION. HE HAD THE TUMBLERS OFF. SO I DONT KNOW WHY YOUR SAYING THE TUMBLERS ARE MAYBE WORN OUT.
Old Jun 22, 2012 | 01:52 AM
Originally Posted by StreetsideStig
Hey Guys,
Thanks!
AND AS FOR YOU MY FRIEND. WHEN YOU GET THE CHANCE TO SEE THAT CAR AGAIN DO THIS. WITH THE KEY OUT DISCONNECT THE IGNITION SWITCH FROM UNDER THE STEERING WHEEL HARNESS. IF THE BEEPING STOPS THEN YOU HAVE A BAD CONTACTS INSIDE THE IGNITION SWITCH IT SELF
Old Jun 22, 2012 | 10:41 AM
I was worried about that, but I think it was actually something inside the cylinder. I sprayed some brake cleaner in there and it stopped. Win! But I'll definitely remember that trick for next time.
273k and this Accord was still going strong. And by "strong," I mean, "leaking oil like a baby leaks everything." It's time for some seal work.
Thanks for the input, guys!
Old Jun 24, 2012 | 11:33 PM
10 Year Member
yes, my fault. he stated something about spraying something in the keyhole as well as disconnecting wires from the cylinder. so that threw me off
ekkscott
Honda Civic (2001 - 2005)
Jun 6, 2012 02:45 PM
donut.
17
Jan 11, 2010 07:03 AM
MaVx
Nov 19, 2008 12:47 PM
b-boy
Aug 14, 2006 05:06 PM
full Circling
Jun 17, 2005 01:34 PM
