98 civic auto to manual - valve cover ground melted - help!
I know this must have been covered alot of times, yes i searched and searched.
ok First 1998 Civic ex auto, changed everything out to manual even pedals and such, finished it up today, and went to go put he negative battery cable on, and the ground from the valve cover to the frame melted, was a bright orange color and melted. What i dont get is why the braided clutch line warm? when we never got the chance to start the car.
Problems:
No lights on cluster besides ebrake and seatbelts
used manual p2p and have no CEL on, tried auto ecu too
braided clutch line gets hot and hotter when battery is connected.
fuel pump doesn't prime
Radiator fan turns on and stays on now even when key is out (getting direct power somewhere?)
where does the sensors on the clutch pedal go? i have to pin it out to something?
Please i need help with this. first time conversion.
no negative comments, im new a this and learning.
Problems:
You have something horribly wrong in your wiring. Did you hook the correct wires up for the auto- Man swap? Check all your grounds. Go over everything you touched that has to do with the wires.
its actually my buddies car, if i had it here i still be working on it lol, but ill go over all grounds again...but why does the clutch line get so damn hot to touch?, btw noob ?, but there are only 3 grounds in the engine bay am i correct?
Go check the wiring first. Because if THIS
doesn't sound like a wiring issue then I don't know what does. I wouldn't be surprised if you fried a lot of the electrical in the car.
GOOD NEWS, found out the problem was the starter. the ground on the starter wasn't covered. covered it now lights and everything comes on. whoo glad it wasn't worse. wired up clutch interlock switch, reverse lights, and ignition. started the car up today and it ran. but had a problem, since it was my first time doing this i over read the part of the auto and manual intake manifold, dang iacv, so ill be switching that over....thanks guys that tried to help, appreciate it!
norcalboy_abe
12
Feb 14, 2007 08:55 PM
vaypourus
Oct 29, 2006 08:56 AM
konidude
Nov 1, 2005 12:32 PM
