95 civic - extreme electrical malfunction, dash and reverse lights don't work
Old Jun 20, 2012 | 05:44 PM
jdreadjdm's Avatar
Default 95 civic - extreme electrical malfunction, dash and reverse lights don't work
my 1995 civic is having an extreme electrical malfunction, lets start at the begining i bought a car for 2200$ 91000 miles on a d15b7, 5 speed, good buy? err wrong spent 1600 on parts i didnt see broke. besides that i noticed the reverse lights did not work properly, not knowing that this will be the biggest nightmare ive ever had to deal with, i checked the switch, its good, 12 volts both sides i pull all the fuses its still getting 12 volts.... wtf, i pull the ECU relay and bam it kills it, i decide to replace the fuse box thinking its the integrated control unit and nope waste of money all it did was make matters worse, now i have NO dash lights or reverse lights, and i dont have money to give to a mechanic to fix it because of course i spent 1600 on axles and ****. i would really LOVE some help, PS- typing out of anger just got out from a 105 degree floor board.
Old Jun 20, 2012 | 06:43 PM
94_civic_dx's Avatar
Default Re: need help before i go insane,
Did u check your fuses for dash light..mine did the same thing kept blowin fuses for the dash turns out my radio harness was hitting some metal and blowin fuses check that my 2 cents hope it helps
Old Jun 20, 2012 | 06:45 PM
grumblemarc's Avatar
The Grumpiest
Are the engine and cabin harnesses all hacked up?
Old Jun 20, 2012 | 09:07 PM
EsotericImage's Avatar
Retired Moderator
sounds like it was in a flood at some point
Old Jun 21, 2012 | 07:42 AM
jdreadjdm's Avatar
the car came from VA so no floods here lol, but yeah i checked all fuses but i will check the radio and stuff like that, if no luck ill just rewire the reverse switch to the tailights because its been an extreme hassle
Old Jun 21, 2012 | 07:44 AM
jdreadjdm's Avatar
and yeah the harnesses are all good to go, when i unhook the harness from top right corner by fuse box it kills it meaning most of the wiring should be good in the bay correct?
Old Jun 21, 2012 | 07:47 AM
jdreadjdm's Avatar
the kid i got it from was young and left out numerous things motor mounts/bolts/exhaust bolts/ interior pieces, typical kid.
Old Jun 21, 2012 | 07:56 AM
Former User's Avatar
Default Re: 95 civic is having an extreme electrical malfunction
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Jun 21, 2012 | 08:16 AM
Default Re: 95 civic - extreme electrical malfunction, dash and reverse lights don't work
1) Buy a digital multimeter so that you can test components before replacing them.
2) 10A dash fuse 15 controls voltage to the reverse lights. Use your multimeter to test whether both top test tabs of installed fuse 15 have battery voltage with the key in ON(II).
3) 10A dash fuse 19 controls voltage to the cluster and climate control lights, as well as the taillights/parking lights. Do the latter lights work?
4) Exactly describe the original problem with the reverse lights. What "ECU" relay did you pull?
Old Jun 21, 2012 | 10:49 AM
jdreadjdm's Avatar
i have a multimeter and the test light, its the 15a ecu fuse my dad said, and the 10a dash fuse is not blown i will check the voltage in just 20 minutes, will get back as soon as possible with a response.
Old Jun 21, 2012 | 11:07 AM
What's your response to these^ points?
Which 15A ECU fuse? There's more than one.
If you want good advice, you need to provide detailed and precise information.
Old Jun 21, 2012 | 11:13 AM
jdreadjdm's Avatar
my original problem with my reverse lights are its getting power to the switch from somewere and still do not light up, when i have all the fuses pulled. except my 15a ecu fuse in the top left corner under the hood.
Old Jun 21, 2012 | 11:15 AM
jdreadjdm's Avatar
the dash lights do infact work my dad just turned the dimmer off when he was ppulling fuse box ,
Old Jun 21, 2012 | 11:21 AM
Post a picture of the switch that you believe is for the reverse lights. Where exactly is it located? What wire colors do you see in the switch?
Old Jun 21, 2012 | 11:26 AM
jdreadjdm's Avatar
its on the transmission under the distributor, ill go snap a pic
Old Jun 21, 2012 | 11:38 AM
jdreadjdm's Avatar
the switch is in the middle
Old Jun 21, 2012 | 11:41 AM
Post pictures of these wires and the connector where you probed for voltage.
Is there voltage on both sides of the switch only when the transmission is in reverse?
Old Jun 21, 2012 | 11:55 AM
jdreadjdm's Avatar
there is voltage on both sides of the switch in reverse and in neutral with key switch on[II] it is only reading 10 volts which is another ???
Old Jun 21, 2012 | 11:59 AM
How do you conclude the switch is good when you get this^ result?
Wire colors?
Pics of wires or connector that you probed?
Old Jun 21, 2012 | 12:08 PM
jdreadjdm's Avatar
at one point it was reading 12 volts. brb with pics
Old Jun 21, 2012 | 12:28 PM
jdreadjdm's Avatar
the switch has two good splices in the wires (green and black) right before the connector
Old Jun 21, 2012 | 12:30 PM
Can't help you if you won't answer all questions and post the requested pictures.
Old Jun 21, 2012 | 12:34 PM
jdreadjdm's Avatar
give me a minute
Old Jun 21, 2012 | 12:41 PM
jdreadjdm's Avatar
Old Jun 21, 2012 | 01:29 PM
jdreadjdm's Avatar
other place i tested was were it inserted into the tranny
