Major transmission issues or ?
My car makes a good bit of power and I have never had drivetrain issues untill the other day. while going threw the gear (floored) i bagned third. Sounded like I i had something draging on the ground it was a hellish noise. I coasted to a stop to check if shift linkage or something had come off. While at idle it started sounding like metal on metal hell. When I let the clutch out while its in gear it makes a awful grinding sound but the car will roll foward. Wrote it off as a bad night and trailered the car home. I went out and started the car today and no grind at idle this time but when i put the clutch in it makes a brief grind and when i let it out it makes a brief grind. No with the car completely in nuetrual not in and gear what so ever and no clutch input at all (not depressed) . I gave the car slight revs and it made a grinding and started rolling foward like a automatic. There is also fluid leaking between the block and tranny out of the inspection cover by the oil pan not sure what it is just saw a BIG stain. Unfortuanatly my car was bought not personally built so my knowledge about the honda game lacks lol. Does this sound like a textbook gernaded tranny or clutch or combination of both.
thanks,
Dan
thanks,
Dan
Take the transmission off, crack it open and inspect it. Stop causing any more damage by torturing it. Looking at it scratching your head isn't going to tell you anything.
eg6madness
Apr 16, 2008 07:02 PM
8YourV8
Dec 31, 2007 07:43 AM
