F20B swap in 94 Accord
Old Jun 20, 2012 | 03:14 PM
MMMGIRL's Avatar
Default F20B swap in 94 Accord
My buddy just ordered this engine and were going to throw it in his accord, now I have a couple questions about this swap. Since the motor is OBD2 and the car is OBD1 shouldnt I be able to take a Intake Manifold and distributor off of a OBD1 H22/H23 and use it? And will I be able to use the stock CV axles that are in it now with the F22?
Old Jun 20, 2012 | 08:14 PM
nus_dogg's Avatar
Default Re: F20B swap in 94 Accord
Yes, you can swap the F20B IM for a OBD1 H22 one to retain the 2-wire IACV and use an OBD1 H22 distributor so that it can be a plug N play. As for axles, you can use the Accords. Just make sure that if you're using an Accord intermediate shaft, use the driverside Accord axle or if you're using a Prelude intermediate shaft, use a prelude driverside axle. The passenger side won't matter as far as I remember. But I read that the Prelude axle will bind when used in an Accord. So stick with the Accord axles since they're made for that chasis.
Old Jun 21, 2012 | 08:55 AM
MMMGIRL's Avatar
Thanks for the info!
Old Jun 21, 2012 | 09:07 AM
villc713's Avatar
No need to change intake mani everything will hook up properly.
Old Jun 24, 2012 | 02:39 PM
MMMGIRL's Avatar
No it wont considering im putting a OBD2 motor in a OBD1 chassis and the IACV on it has a different plug
Old Jun 24, 2012 | 03:16 PM
villc713's Avatar
So remove your old iacv and install it pretty simple considering f/h most parts are interchangeable
philafelman
Feb 5, 2008 02:35 PM
Subwarrior
Apr 1, 2005 05:07 AM
rdawg000
Mar 10, 2005 05:53 PM
ITR632
Jul 19, 2004 03:38 PM
sd90mac1
Jun 23, 2004 10:39 AM
