Del Sol with Mitsubishi parts? What is this?
Old Jun 19, 2012 | 03:15 PM
Nate Case's Avatar
Default Del Sol with Mitsubishi parts? What is this?
So i had to rebuild my d16z6 due to some blown ringlands. And Now im to the point of putting my motor back in and hooking all the wiring up and i run across this little black box(pic below). Half the wires were already disconnected from my wiring harness(pic below). My question is, What is this and do i really even need it??
My d16 is turbo'd. its runnig mitsubishi injectors. Im wondering if this is what the little black box is for. Any help would be nice..
Old Jun 19, 2012 | 03:30 PM
ManTyme's Avatar
Default Re: Del Sol with Mitsubishi parts? What is this?
resistor box so the injector will work... alot of people use dsm injectors
Old Jun 19, 2012 | 03:33 PM
Dc4LsTeG's Avatar
EK9
Yes looks like you have dsm injectors and a resistor box(which I do believe they require). Not really sure about the wiring for it, have you had the car running like that at all?
Old Jun 19, 2012 | 03:34 PM
Dc4LsTeG's Avatar
EK9
What car is this on?
Old Jun 19, 2012 | 03:45 PM
Nate Case's Avatar
Its on a del sol. Okay, well heres my next question.. my wiring harness has 8 wires and the resistor box has 5....how ya hook that up?
Old Jun 19, 2012 | 03:47 PM
grumblemarc's Avatar
The Grumpiest
Check it. On the resistor box. Four are power to the injectors and one ground. On the harness. Four are for power to the injectors and four are ground. Think about it.
Nate Case's Avatar
I have not had the car running yet so, not sure if it will work without it
Old Jun 19, 2012 | 03:50 PM
Dc4LsTeG's Avatar
EK9
Originally Posted by grumblemarc
Check it.
Don't, it won't, and you could possibly do damage. Just be positive you wire it correctly
Old Jun 19, 2012 | 03:53 PM
The Grumpiest
If you do you risk burning up the ECU. At least the injector drivers in the ECU at any rate.
Old Jun 19, 2012 | 05:08 PM
Nate Case's Avatar
Yea thats no good.
But now im looking at it, the resistor is easy to figure out the power and ground. But the hard part is, my wiring harness is all just black and yellow wires. no distinct one that would show the ground wire.
Old Jun 19, 2012 | 05:22 PM
The Grumpiest
Multimeter time.
Old Jun 19, 2012 | 05:28 PM
Nate Case's Avatar
Any other way without multimeter? dont have one handy
Old Jun 19, 2012 | 06:50 PM
Dc4LsTeG's Avatar
EK9
Nope.. Buy one
Old Jun 19, 2012 | 11:04 PM
jbpnoman's Avatar
If you're working on a car, a multimeter is the second tool you should buy, right behind a reliable socket/ratchet set.
Old Jun 21, 2012 | 01:16 PM
Nate Case's Avatar
Well, I guess imma buy one. Never really worked on cars before. This is my first build. I think its turning out pretty nice..
Old Jun 21, 2012 | 01:20 PM
Dc4LsTeG's Avatar
EK9
Old Jun 21, 2012 | 01:22 PM
Nate Case's Avatar
whats wrong with it?
Old Jun 21, 2012 | 01:24 PM
Dc4LsTeG's Avatar
EK9
If you like it, then nothing
Old Jun 21, 2012 | 01:26 PM
The Grumpiest
As long as YOU like it.
Nate Case's Avatar
Right on.
Old Jun 21, 2012 | 01:28 PM
Nate Case's Avatar
Cool, Thanks for the help fellas.
Old Jun 21, 2012 | 05:32 PM
crawfo661's Avatar
if you run the correct impedance injectors for your ecu you can throw away those dsm 440's and the resistor box. i've ran the dsm's tho, it works if you are on a budget
Old Jun 21, 2012 | 05:38 PM
Dc4LsTeG's Avatar
EK9
If your interested OP im selling high impedance injectors
Old Jun 21, 2012 | 05:47 PM
crawfo661's Avatar
For future reference & clairity: Injectors are constantly fed +12v switched on one side (yellow w/blk), via the main relay. The other side (multi-colored wires) run directly to the ecu, to the internal injector driver mosfets, which switch them to ground when they need to fire. It's kinda the opposite of how most electrical parts are fed, which is always grounded with a switch connected to +12v.
This is stolen from RealHomeMadeTurbo member HiProfile, Certified OG
Old Jun 22, 2012 | 05:13 PM
Nate Case's Avatar
OOO yeaaaa.
