94 Civic/D16Z6 -- no power to fuel pump ??? HELP
Old Jun 19, 2012 | 10:27 AM
dang-eg's Avatar
Default 94 Civic/D16Z6 -- no power to fuel pump ??? HELP
i have a 94 eg sedan with a z6 i have spark and ecu is good and the fuse 31 and 24 r good and were tested and the main relay plug was tested 5 to 7 jump works and so does 1 to 7 jump so this tells me my relay is bad but its a brand new relay what to do ??? oh and G101 ground is good plzzz help befor i burn this thing lol
Old Jun 19, 2012 | 10:31 AM
dang-eg's Avatar
Default Re: no power to fuel pump ??? HELP
oh and it would not start so i got the main relay and still nothing thin i got a ecu and it rain for about a mint then died
Old Jun 19, 2012 | 11:34 AM
dang-eg's Avatar
also cel comes on then goes offff then i try it start it and it comes on then back off
Old Jun 19, 2012 | 11:54 AM
Former User's Avatar
Have you opened up the original and recent ECU to look for a blown component?
Do these^ ECUs work in another car?
Old Jun 19, 2012 | 11:57 AM
dang-eg's Avatar
yes i have no burt smell or any thing ?the with the main relay hooked up i test the pin 7 for volts with a test light and it lights up but is dim
Old Jun 19, 2012 | 12:01 PM
dang-eg's Avatar
just moved out of stat and dont know anyone here to help that has a eg or teg to test it
with my old ecu i had no fuel pump signal at the main relay from ecu and with the new ecu i did the same test and it seems to be getting signal
Old Jun 19, 2012 | 12:11 PM
The question is: "Is your car frying ECUs?"
Did you open up the ECUs and inspect them? Post pictures.
Old Jun 19, 2012 | 12:13 PM
dang-eg's Avatar
thats what i was thinking ill take pics now how do i post the pics ?
Old Jun 19, 2012 | 12:23 PM
See stickies at the top.
Old Jun 19, 2012 | 12:32 PM
dang-eg's Avatar
can u send link for sticky the only one i c is add pics for diy and there is no papper clip on the reply thanks a lot
Old Jun 19, 2012 | 12:35 PM
You can use this^ method. You'll see the paperclip when you click reply.
Also click here:
https://honda-tech.com/forums/showpo...37&postcount=2
Old Jun 19, 2012 | 12:45 PM
dang-eg's Avatar
Also click here:
p28-1 was the stock on i pulled out[IMG][/IMG]
Old Jun 19, 2012 | 12:47 PM
dang-eg's Avatar
p28-2 got this one off craigslist and it didnt work [IMG][/IMG]
then got a p06 cuz i could not find any p28s and it rain then died
Old Jun 19, 2012 | 12:48 PM
Also post pictures of the component side of the ECUs.
Old Jun 19, 2012 | 12:50 PM
dang-eg's Avatar
the p06 is socketed but has no chip and the link on is is cut so it will run stock from what i was told
Old Jun 19, 2012 | 12:51 PM
Pictures?
Old Jun 19, 2012 | 12:57 PM
dang-eg's Avatar
ok give me a sec for the top pics
also p06 its dirty
Old Jun 19, 2012 | 01:06 PM
dang-eg's Avatar
p06 [IMG][/IMG]
p28-1
p28-2
sorry for pics only have cam phone and it sucks
Old Jun 19, 2012 | 01:10 PM
I'm not seeing anything out of the ordinary. Do you?
Old Jun 19, 2012 | 01:13 PM
...the main relay plug was tested 5 to 7 jump works and so does 1 to 7 jump
Do these tests still cause the fuel pump to run?
dang-eg's Avatar
nope and no burt smell or any thing but with both p28s my cel stayed on and no signal to main relay for the fuel pump but when i put the p06 in it started and rain the died but there was no cel
Old Jun 19, 2012 | 01:14 PM
dang-eg's Avatar
yes that test makes the pump run
Old Jun 19, 2012 | 01:19 PM
dang-eg's Avatar
yes it does but if i leave to relay hooked up and test if power is going to 7 with a test light it lights up but not a lot
Old Jun 19, 2012 | 01:23 PM
Do you have a multimeter? There are some electrical tests that should be informative.
Old Jun 19, 2012 | 01:32 PM
dang-eg's Avatar
no but i can go get one what should i look for
