Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
08 Civic sedan, need suggestions 4 more power!!
Old Jun 19, 2012 | 08:27 AM
Maxwellspeeds's Avatar
Default 08 Civic sedan, need suggestions 4 more power!!
Ok so I have a friend that wants to power up her Civic as the titles suggests. Most of my experience is with boosted mitsubishi's and its not like I can put a bigger turbo on her civic and call it a day.
SO I would like to take some suggestions as to what other civic owners are doing in there quest for MORE SPEED!!
BTW we dont have a whole lot to spend on this project, so the turbo kits are out of the question, and I don't believe she wants to pull the motor for any internal upgrades. Please post what parts worked for you, brands, and overall experience. I know we purchase a Flashpro for our tuning needs, I have mostly used ECUflash for Mitsu's and subies. But most tuning is all the same.
Question, are there pre made base maps to download respective to the parts we install? ie, exhuast, cold air intake...
Thank you for your time
Maxwell
Old Jun 19, 2012 | 12:13 PM
bairdandrew77's Avatar
Default Re: 08 Civic sedan, need suggestions 4 more power!!
Simple upgrades like K&N CAI, skunk2 manifold, and exhaust swap are the most common ones and usually keep people happy for a while
Old Jun 19, 2012 | 01:22 PM
Ok that sounds good. Where is a good place to purchase honda parts from. I usually buy through MAPerformance, AMS, but they are limited on honda parts.
Also if anyone could chime in that is fluent in the tuning of honda ecu's I would like to bounce some questions off ya!
Thanks
Old Jun 19, 2012 | 03:25 PM
doood's Avatar
been there done that
what model civic?
Old Jun 19, 2012 | 03:32 PM
mikecp's Avatar
you must get flashpro.
MUST.
Old Jun 19, 2012 | 06:21 PM
tapiasradiator05's Avatar
CAI, skunk2 race header, exhaust, flashpro
Old Jun 20, 2012 | 07:03 AM
Yes we will be working on getting all of these items. But Will this require a custom tune with flash pro? or is there some sort of base map already made for this set up?
Originally Posted by doood
what model civic?
Not really sure? I do know its an '08 Civic Si 4 door.. What other sub models are there that it could be?
Next question.. Are the parts listed above the best we can do before we have to start thinking about forced induction?
Old Jun 27, 2012 | 09:43 PM
civic20's Avatar
Flashprotuning.com has basemap. Get an etune it is the best route. Vit is doing almost everyone I know. From turbo to NA.
Out K series can handle a nice bit of psi. My friend is running 14 or 16 lbs and he is killing cars. Hardest part is traction. I would recommend if you are going to pull the motor do internals so if you do crank the boost up it will not blow up the rods/pistons.
Old Jun 28, 2012 | 05:49 AM
HRsi-dan's Avatar
Lots of turbo people have seen 400-500 FWHP on stock internals. The weak point tends to be the tranny when you start making that much power. With a good tune, the engine will last quite a while.
Old Jul 9, 2012 | 01:04 PM
Turtle_FA5's Avatar
intake, header, exhaust, flashpro makes the biggest difference. I'd also say cams pulleys, or just drop a K24 block with your k20 head
Old Jul 15, 2012 | 10:39 AM
Rarytas's Avatar
real light weight wheels, not knock offs, will make the car seem like it accelerates a bit faster. $2000 tho, for not "real" hp difference
Old Jul 16, 2012 | 10:53 AM
HRsi-dan's Avatar
You could get Enkei RPF1's for less than a grand for all 4.
Old Jul 16, 2012 | 01:10 PM
DaveSi677's Avatar
Agreed
Old Aug 8, 2012 | 10:50 AM
gappy4444's Avatar
DSport magazine actually says the connecting rods are usually what breaks in mid-high boost applications
Old Aug 18, 2012 | 10:21 AM
N8vSi's Avatar
Keep us posted!
Old Sep 20, 2012 | 11:50 AM
mattdexter's Avatar
flashpro is what they tell me
Posted from Honda-tech.com App for Android
Old Oct 17, 2012 | 02:07 AM
h22boii's Avatar
Still looking for parts? I gots a bunch left over or replaced from my build
Old Nov 15, 2012 | 10:56 AM
BastardsFA5's Avatar
Honestly what i believe is all the post prior to mine are all correct on getting power to your car, but the next question would be do you want more :D.
once you get power some would always want more. For me i have a 2008 honda civic si FA5 (4DR) and im working on all motor civic. i dont care to much for Aspiration except for the cool BOV sound . all motors cars with internal upgrades is just more reliable if your looking to have this car your DD.
Old Nov 18, 2012 | 04:08 PM
Nathen's Avatar
unless you are running ppg or similar gears your tranny will go long long before you break any rods. my buddy rebuilt his tranny 3 times before he broke a rod.
Old Nov 18, 2012 | 04:40 PM
K5^'s Avatar
K5^
Brand New
On top of the I/H/E/Fp/cams, change up the TB and replace the RBC with the RRC.
Beyond all of this, one would need to work on internals.
Don't forget to address tires/suspension. You can add all the power in the world, but if you can't put it down effectively, you have wasted your time.
Old Nov 22, 2012 | 07:59 AM
PickleTeg's Avatar
My car with just I/H, Flashpro and a NST crank pulley actually moved pretty well. Flashpro is a must!!!!
Old Nov 22, 2012 | 03:32 PM
DaveSi677's Avatar
Agreed with Ken...
Also clutch and flywheel upgrade will help distributing the power. Weight reduction will make it faster too...
Old Nov 27, 2012 | 07:31 PM
DK_OEM's Avatar
skunk2 is the best i can say
Old Dec 1, 2012 | 07:23 PM
doood's Avatar
Lol
Old Dec 19, 2012 | 01:37 AM
Varion Icaria's Avatar
A turbo would be the best gain but it can be pricey. As far as what the K can handle boost wise? If you're not tuned with bigger injectors and hit 14/16 psi, You can expect a rod to start to bend like a banana. Must always maintain a proper AFR in order to keep a proper running engine and maintain power. Flashpro's a must to keep the engine stable. I just finished tearing down two blown K20Z3's. One was from oil pump failure + vtec + 12psi of boost, Shot a hole in the block. Another one was a spun bearing due to an improperly installed Type S oil pump. Any other help with power upgrades feel free to contact me.
