Transmission & Drivetrain Gearboxes, Differentials, Clutches
scraping sound from transmission
Old Jun 19, 2012 | 08:25 AM
spjr90's Avatar
Icon2 scraping sound from transmission
I have a 95 civic. There is a rattling sound coming from the trnsmission when in neutral. And a scraping sound when it is put into gear AND moved in 1st2nd&3rd. only after 30 mph and in 4th and 5th you cant hear it. What can this possibly be? Throw out bearing maybe...?
Old Jun 19, 2012 | 09:15 AM
Phillybiker's Avatar
Default Re: scraping sound from transmission
it could be your throwout bearing and a number of things inside of the trans. Maybe its not your trans, jack it up and check everything out.
Old Jun 19, 2012 | 09:24 AM
kyden's Avatar
most common is an input shaft bearing.
Old Jun 19, 2012 | 10:33 PM
Mista Bone's Avatar
D Tranny Guru
stopped in Neutral, engine running does the noise go away when you press the clutch pedal down?
If so ISB or Input Shaft Bearing.
Old Jun 25, 2012 | 06:36 AM
spjr90's Avatar
Thanks for the tips. I just pulled the tranny out yesterday. So today ill be looking more into it. Thanks again for the help. It was all very useful.
Old Jul 2, 2012 | 07:04 AM
MR.johnson's Avatar
I just did an isb that made zero noise at idle but on decel it sounded like the trans was breaking in half.
TimelessLlama
Sep 24, 2018 01:59 PM
OneFire
Aug 7, 2009 04:24 PM
diamondstarsforever
Jun 15, 2009 09:50 AM
IGotVTECyo
Nov 15, 2006 06:05 AM
ElectronBlueGsr1.8
Jul 27, 2004 05:24 AM
