Crazy CRvtec part out! No ebay parts here!
Were do i start. Im parting this build out for many reason none of them the lack of nice parts or potential here. The pics will show you how much money, pride, love and care i have into everything!
Golden Eagle sleeved B20z2 (bored and honed to 84.5mm), O-ringed Deck, Golden eagle billet girdle (clearance for alum rods), ARP main stud which block had a full main align bore done at golden eagle with the new studs, ALL NEW OEM(ITR oil pump, ITR oil pan, ITR oil pick up, ITR windage tray, ITR water pump) All bolts and seals are new oem as well. Engine had never been run or fired.
SOLD
DOES NOT!!! include rods, pistons, crank.
B16a2 Head, Supertech Drag springs and Ti retainers, Stock valves, ITR Upgraded LMA's, .010 decked, ports had castings removed no material removed, New OEM valve seals, all rockers and cam caps included, new oem locators, orings, oil orifices.
$550.00 obo
Blox intake manifold, 70mm omni power TB, Intake was cut apart and had a full cleaning and port work done, new oem gasket, all vacuum fittings are high pressure lines, I will include extra fittings and about 10ft of line, and wrinkle black coating.
SOLD
Skunk2 pro1 cams BNIB
SOLD
Injector dynamics ID1000 injectors BNIB, includes the super nice plug adapters and top hat adapters for all obd1 honda and many others.
SOLD
Precision 6262 billet journal bearing turbo t3 flange .82 a/r. Turbo spins but needs rebuilt was ran low on oil. Neither of the wheels touched the housing there is no shaft play just drags when turned from lack of oil.
SOLD
Aeromotive 340lph stealth pump. part number 11142 BNIB
SOLD
Golden eagle black b16 cam gears. brand new never used comes with oem key's
$180.00
Golden eagle high strength head studs. The were installed torqued and taken off never been ran or heat cycled.
$100.00
Wiseco pistons 11.5:1 CR 84.5mm part number:K567M845 (crv/vtec pistons) , k1 h-beam rods part number:HH5394ACFB4-A , the pistons had side gas port and top and side coatings add at diamond pistons. They were installed into the engine but was never started.
$700.00obo
b16 edelbrock fuel rail fits larger bocsh larger orings
SOLD
I also have a bare gsr head ill let go for 100 bucks
A TON!!! of OEM honda parts like tensioner pully, timing belt, all the A/c pully stuff with bolts and brackets,
Hondata b16 intake mani gasket BNIB 30 bucks
b16 vtec solenoid used 50 bucks
good b20 crank 100 bucks
all this stuff is new really have alot of love in everything. when you get the block or head a bunch of extras will come with i didnt even talk bout lol the products will be worth every penny lol. these parts will built and picked for a 700hp 10k rpm street car. please message me with any questions!
SOLD
$550.00 obo
SOLD
SOLD
SOLD
SOLD
SOLD
$180.00
$100.00
$700.00obo
SOLD
You were online lastnight.. can you please answer my pm about when the gasket will arrive or just refund the money so I can just order another one. I want to install this thing before i put my motor in.
Hello!!!!! Send me my money back, Please. Ill open a claim tomorrow if you don't send the money back today. Thanks for nothing, big waste of time.
PirateMcFred
158
Apr 14, 2011 10:50 PM
cl3an_98gsr
15
Jan 7, 2010 04:52 PM
TurboDANDEE
Feb 11, 2004 01:11 PM
