H2b swap in Ek - 80A Battery fuse blows
Old Jun 18, 2012 | 09:55 AM
5exy_Ek's Avatar
Default H2b swap in Ek - 80A Battery fuse blows
Finally finished the H2b swap in my friends EK and we went to hook up the battery and the main 80 amp fuse labeled battery blew. We tried it a second time and blew a second fuse. Im sure its something really stupid but i havent seen this problem before so if anyone can share some ideas it would be really appreciated. Setup is a 1997 ex with an H22A and a GSR transmission, using the EX harness and a P28 on Hondata s300
Old Jun 18, 2012 | 10:09 AM
Former User's Avatar
Default Re: H2b swap in Ek Battery fuse problems
If you disconnect the large white alternator wire from the hood fuse box, does the fuse stop blowing?
Old Jun 18, 2012 | 10:27 AM
5exy_Ek's Avatar
Default Re: H2b swap in Ek - 80A Battery fuse blows
Ill have to check it out tonight when i get more fuses, if the fuse doesnt blow when i take the alternator wire out of the box what would the problem be?
Old Jun 18, 2012 | 10:41 AM
A short to ground in the white wire or in the alternator.
lakeviewman
Aug 8, 2025 02:07 PM
mtg
Nov 29, 2009 07:44 AM
rhd_ef8
12
Apr 29, 2007 11:27 AM
rasta420
Nov 6, 2002 08:41 PM
4doorH22
Nov 27, 2001 09:48 AM
