shop cleaning thread, tons of parts. stl.
[B]Fire sale!! This is the thread you guys have been waiting for. I am parting out my drag car and cleaning out all the parts in my garage. The drag Car never saw the track so most of these pieces have been on the car only for start up. All of the pieces are located in St.louis (Cottleville to be exact) mo 63304. I am willing to ship at new owner’s expense. All prices are obo and I will negotiate if of items are purchased together.
The ef civic shell – what it will come with is a good title, walbro 255lph fuel pump, rear disc swap already on, front integra knuckles and brakes with new wheel bearings, extended studs up front, a traction bar kit, front shocks with h &r lowering springs ill even throw in the rears, rear aluminum lower control arms, a passenger seat, fenders, hood, and anything else I can find that belongs with the car. Now the car will take some work to get it back if you wanted to get it street legal as in the front core support put back in and headlight buckets but as with any project anything is doable does not have wheels you will need to bring some. 700$ obo
b series side exit header 4-2-1. This header is loud and the only words to describe it are amazing. no you cannot use it on the street. Comes with o2 sensor 600$ obo
ls distributor, with msd coil, coil wire, msd cap and rotor, fresh ngk spark plug wires 125$ obo
ls long block engine 190 compression, new timing belt, fresh rebuild, custom valve cover no distributor 300$ obo
ef civic b series linkage with short throw 40$ obo
ef civic b series axles with int shaft 75$ obo
ef cheap b series swap mounts just the drivers and trans 30$
gsr cable transmission leaks not too sure where from 350$ obo
Radiator and fan 75$ obo
Full complete drag car harness. Here is the thread where stole made the harness http://stlhondas.com/forums/showthread.php?t=23850 There is no fluff with this harness just the necessities. All coupled to a Moroso switch panel with push button start. Comes with relays and all just hook up to the engine, a fuel source, and a positive battery connection and it is good to go. 450$
Fiberglass one piece front end for ef. No brackets no nothing 500$ obo
Sunpro tach 75$ obo
Ignition stacker 50$ obo
Taylor battery box 100$ obo
Prelude wheels 14 inch with center caps 4x100 200$ obo
Bride racing seat with ef rails has a tear and kinda faded 75$ obo
Bbs wheels 14 inch 4 x100 only two center caps 350$ obo
2 front 5 spoke knock offs with bfg drag radials with bad tires 150$ obo
B series turbo manifold 75$ obo
integra ls heads x2 20$ obo
ls skunk 2 intake manifold old style 150$ obo
Skunk 2 pro series 70mm throttle body 125$obo
Autometer carbon fiber volt meter 25$
Td05 turbo 100$ obo
Down pipe 40$ obo
bad d series si trans needs synchros 60$ obo
b&m fuel pressure gauge 20$ obo
b series clutch and pressure plate not sure if still good 50$ obo
14 inch hub caps x 4 20$obo
Audiobahn speakers 30$ obo
Eg gauge cluster with tach no idea what happened to the fuel and coolant temp 20$obo
obx lsd with upgraded washers and bolts 150$ obo
dsm 440s 60$ obo
very crappy b series turbo manifold 20$ obo
good looking integra power steering pump 30$
Ef civic gauge cluster with tach 60$
Brand new d series d16z6 distributor 125$
Stinger fuse block and fuse holder 30$
Eg painted black interior pieces 40$ obo
Hydro vss 25$ obo
Perfect gauge surround eg 20$
Misc axles 25$ a piece
Stupid ramps I never use 20$ obo
Crappy shop tv no hdmi 20$
Short ram intake 15$
Sunpro tach 75$ obo
Td05 turbo 100$ obo
Down pipe 40$ obo
dsm 440s 60$ obo
Hydro vss 25$ obo
