Can anyone help me identify the parts in this Gasket Set?
I'm not sure if I'm allowed to post links (I'm new here), but I'm referring to the "DNJ FGS2019" Full Engine Gasket Set for a '92 Accord (F22A6 engine). I've tried to contact some shops and I emailed the manufacturer but I didn't get a response. I hope someone can tell me if this set includes any of the following:
-Balance Shaft Seal
-Camshaft Seal
-Crankshaft Seal
-Distributor O-Ring
I don't have enough experience to identify these parts from the few blurry pics that I found. Also, I'm ordering from Europe, so I won't be able to check until I get it...
-Balance Shaft Seal
-Camshaft Seal
-Crankshaft Seal
-Distributor O-Ring
Multi-layered steel head gasket
Intake manifold gasket
Exhaust manifold gasket
Valve cover gasket
Viton valve stem seals
Camshaft front
O-rings
Front seal gasket
Rear seal gasket
Water pump gasket
Timing cover gasket
Other Small Gaskets
Valve cover gasket
Camshaft front
O-rings
Front seal gasket
Rear seal gasket
Water pump gasket
Timing cover gasket
Other Small Gaskets
jodyboy
Dec 30, 2012 04:43 AM
EG_Civic_Si
Oct 31, 2005 03:13 PM
jbell
Jan 7, 2005 01:56 PM
