Help with EF 91 build
hello guys, I am in the process to throw a B18 GSR in my 91 civic, however I just found out that the front engine mount bracket does not align properly. I have been researching and yet can't find the right bracket... is it the 93 integra? is it the 94 integra? or is it the EF 91 (japanese) which came with B16 engines? any help would be appreciated
Thank you,
Thank you,
To fit your motor, you will need the DA Integra driver side post mount or the bracket that's attached to the block itself, DA shift linkage that needs to be cut and welded to fit or simply buy an adjustable linkage, you need aftermarket mounts, innovative, Hybrid, Ebay if you want. rear DA t bracket if you're using cable trans. DA halfshaft/intermediate shaft from a 5spd. automatic will not fit. CB7 accord driver side radius rod if you're using the pulley that comes with your motor.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Just in case you get confused. Also, you could order a '90-91 Integra front trans mount and modify as necessary to hook it up...
Okay guys, I have completed the swap (a month ago actually) I am sorry but my PC got screwed and was not able to access the forum for a little while. The issue was the engine mounts... the jackass who sold it to me mixed it up and game me wrong ones. So, I got Hasport engine mounts and issue resolved. The friggin' car is not as fast as a fart... clocked 230 km/hr in 7.5 secs which is impressive for a car this old and I was able to go 0 to 60 (m/h) in 5.6 secs... I say not bad... a lot of work still needs to be done (I wish I could post pictures) I need to reposition the battery to the truck to make room for intercooler and so own so forth, however I am happy with the results so far... thinking in adding a supercharge next year
Barbantus
Jul 9, 2010 03:28 AM
