Fs/Ft: Built B18 block for High Comp Ls Or LsV!! 0 miles!!
Old Jun 17, 2012 | 11:48 AM
rwdkid's Avatar
Default Fs/Ft: Built B18 block for High Comp Ls Or LsV!! 0 miles!!
Freshly Built Block For LsV Or High Compression Ls.
0 miles.
Professionally Built.
Will Come With Receipt.
Specs:
B18b1 Block.
Hot tanked.
Machine Honed.
Sonar Checked For Micro Stress Cracks, Came Out Clear.
Decked.
Perfectly Balanced Crank (Balances to 0g).
Ls Rods w/Arp Rob Bolts (Balanced To- 496g each).
New STD Size Main/Rod Bearings and Thrust Washers.
New JDM ITR P73 pistons w/wrist pins (Balanced To-395g each).
New STD Size Honda Piston Rings.
OEM JDM ITR Oil Pump.
OEM ITR Belt Tensioner.
Oem Honda Gsr Timing Belt.
Assembled With Honda Bond.
Assembly lube used in assembly.
New Oil Pan Gasket.
This is first come first serve!
The ONLY trades I'm Interested in are some nice 15-16 inch wheels w/tires, 4x100 +25-+40 offset preferred +cash, or an xbox 360 premium or elite with mw3 and a controller + cash.
Asking $650 o.b.o
Text me @ 909-565-8123
Old Jun 17, 2012 | 12:16 PM
SIKNASTREXO's Avatar
Default Re: Fs/Ft: Built B18 block for High Comp Ls Or LsV!! 0 miles!!
bump...wher was it built at?
Old Jun 17, 2012 | 12:25 PM
RazorsRacing's Avatar
bump for looking.
Old Jun 17, 2012 | 12:44 PM
rwdkid's Avatar
I build all my blocks myself.
HeartBreak Motorsports.
Old Jun 17, 2012 | 05:39 PM
rwdkid's Avatar
***sold****
rwdkid
Jun 16, 2012 07:15 PM
ejcivicdee
Jan 27, 2008 03:20 PM
JDMFerio01
Jun 12, 2005 12:05 PM
dfoxengr
Apr 8, 2005 06:04 AM
Mike K
Nov 29, 2001 05:34 AM
