bad running if not at all b16a. ready to get it done!
Old Jun 17, 2012 | 12:23 AM
standy xsi's Avatar
Default bad running if not at all b16a. ready to get it done!
so i just got a new integra was running abit ruff before i got it but was running.
so it had type r cams and a type r intake that the previous owner wanted to keep.
ive put it all together, this is my secound time duin the timing, everything lined up right double checkd it and all.
ive got all the plugs connected minus o2 sensor becouse the extractors are obdo1
codes are 1 9 and 14
on the video can hear a knocking or a miss? could be becouse im just running a barrelhousing and starter atm to get it going
it doesnt want to start without ne throtle either
how can i diognose this what are your thoughts?
http://www.youtube.com/watch?v=PlwKx...ature=youtu.be
Old Jun 17, 2012 | 09:11 AM
el crapitan's Avatar
Default Re: bad running if not at all b16a. ready to get it done!
do you have the correct connector on the iacv?
checked for ignition?
i believe the cyl1 pos. is necessary for fuel injector sync. i would start there. i believe it's just a pick up coil located inside the distributor. follow the procedure for testing
Old Jun 17, 2012 | 12:39 PM
standy xsi's Avatar
how do i check for ignition and the right iacv plug?
Old Jun 17, 2012 | 01:15 PM
remove a spark plug and reinstall it into the boot. ground it and have someone crank the motor. watch for spark
should be a good solid white firing. also, make sure it is consistent and not random
Old Jun 17, 2012 | 01:19 PM
standy xsi's Avatar
im solo today, is there another way? ill pull them out clean an swap dizzy then report back,
put u hear that hmmmm knocking sort ov sound? sound's like all 4 are not fireing, its not the sound of big or top end! would it be hitting the valves?
duck5985
27
Jun 30, 2015 10:02 AM
duck5985
Jun 20, 2015 06:31 PM
standy xsi
Jun 18, 2012 07:55 PM
standy xsi
Jun 17, 2012 01:48 PM
MIND SET
Aug 18, 2011 01:33 PM
