b series cable trans lever issue.
Old Jun 16, 2012 | 02:08 PM
CRX91SE's Avatar
Default b series cable trans lever issue.
Ok so my clutch was a suspect of failure. i picked up a hydro competition clutch kit and i am using this on my 92-93 cable trans with full 99 si gears in this case. Now my problem is the clutch arm will be almost fully extended to reach the pressure plate also my clutch cable will be fully adjusted to the bottom leaving not much more plastic threads to adjust accordingly. what is going wrong i cant seem to figure this out. .
db owner88
Mar 17, 2009 11:16 AM
btlefedgsr
Apr 28, 2002 04:17 AM
