wheel spacing help
Old Jun 15, 2012 | 03:33 PM
swizz977's Avatar
ok so i wana put 10mm spacers on i have some bbs reps now i kno its unsafe to run the unbolted 10mm but the bolted one wont fit my wheels because the stock stud will stick out.. so i think my only other option is extended lugs but im not sure if they will clear the cap that goes over the lugs the cap apart of the wheel.. what do u guys think
ok well i measured my oem studs are 1.85 i googled it the arp extended ones are 2.85 one inch bigger so i put on a 20mm spacer on my oem and the stud is .5 long so that means the extended will b 1.5 long ok now i measured the clearence for the wheel cap its 1.75 so i shud have enough clearence.. wud of been easier to just get the bolt on tho but my studs will stick out and the back of my wheels have little holes for the multi lug pattern
actuallu somthing like this would work on my wheels because there multilug but these are 15mm wish they were 10 fml http://www.drivenperformance.co.nz/s...idproduct=1512
josh's ep3
17
Jan 28, 2009 11:07 AM
Midori Green
15
Jan 1, 2008 10:39 PM
iperez
Nov 6, 2006 07:16 AM
dunkd
Jul 19, 2005 01:51 PM
hybridreams
Jan 11, 2003 09:47 PM
