Sydney, Australia EGB16 Turbo.
Suspension and wheels :
- 9 inch 6uls bronze with 225 50 15 tyres up front a050 ( 10mm spacer with extended studs and open end lug nuts )
- 8 inch 6uls bronze with 225 50 15 rear a050 ( 3mm spacer with extended wheel studs and open end lug nuts )
- Hardrace front camber kit with bronze bush
- Hardrace Rear camber kit sypherical
- Hardrace adjustable toe arms syperical
- Hardrace Rear trailing arm bushes
- GAB SS coilovers 12kg front 8 kg rear
- Hardrace Roll centre adjusters
- Function 7 lower control arms
- Function 7 subframe brace
- ITR rear sway bar 22mm with hardrace bushes
- ITR front sway bar with hardrace bushes
Interior :
- Stripped interior, bare dash.
- Sound deadning removed
- Half cage
- Omp steering wheel with boss kit
- Fastline shifter
- Tunerview rd1 digital dash
- Genuine Bride zeta III
- Autometre gauges . oil temp, oil pressure, water temp.
Exterior :
- Oem red
- Spoon replica wing
- Spoon replica mirrors
- oem eg6 lip
- VTI sunroof model 1994
- Oem rear wiper delete
Engine :
- Jap spec b16 turbo
- APS custom turbo gt28 with 0.86 rear housing
- 2,5 inch exhaust
- greddy log manifold
- Front mount intercooler
- BOV
- Oil cooler setup
- running on e85 ethanol based fuel
- s300 hondata
- wire tucked engine bay
- eboost 2 boost controller
- Moroso oil catch can
- Fuse box relocated under dash and battery relocated to rear of passenger seat
- Hood dampers
- Removed power steering
- removed heater box and core
Interior :
- Half cage
- Fastline shifter
Exterior :
- Oem red
- oem eg6 lip
Engine :
- 2,5 inch exhaust
- BOV
- Oil cooler setup
- s300 hondata
- Hood dampers
ITR0842
May 28, 2010 08:59 AM
SlowWhiteEvo
Other Make Vehicles
Feb 7, 2010 06:31 PM
