Random EG B-series swap parts
PM is the best method to contact me. I will check this thread every couple of days though. bump if you look! paypal only.
All prices are shipped so take that into consideration please.
everything was pulled from my running 93 hatch with a 91 b18a1/cable trans swap. simply pulled it apart and sold the shell.
new duracraft b-series water pump - $25
EG b-series axles/pair - $70
(fit cable trans, no clue on hydro trans)
aluminum half radiator (manual trans) w/fan + new upper hose - $70
p75 manual ecu - $70 SOLD
EG cruise control motor - $25
EG non-vtec engine harness converted for LS - $70
(note harness has two injector plugs with broken clips)
(I just used zip ties to hold them in place, works fine)
EG B18/cable trans swap motor mounts - $110
will upload pics of the stuff without pics once I get the parts separated from the swap.
96johnson
Jun 3, 2010 02:56 PM
