#34 Fuse blows on 96 Accord EX 4cyl
Old Jun 13, 2012 | 06:23 PM
Tjpphoto's Avatar
Icon2 #34 Fuse blows on 96 Accord EX 4cyl
The #34 fuse on my 96 Accord keeps blowing after a few minutes of running the AC. My service manual suggests that it might be related to the compressor clutch or clutch relay. Can't find any mention of this particular problem on the forum.
Any idea of how to proceed troubleshooting?
Old Jun 13, 2012 | 06:52 PM
nus_dogg's Avatar
Default Re: #34 Fuse blows on 96 Accord EX 4cyl
It's easier if you have a wiring diagram for your year Accord. That way, you can trace it back.
Old Jun 13, 2012 | 07:21 PM
redbull-1's Avatar
Since you have the service manual, you would see the No. 34 (15A) fuse protects the circuits (which shows a white wire) for the radiator fan control module, condenser fan motor, and A/C compressor clutch relay. Start checking the wiring (look for pinched or chafed wiring) and connectors in the circuit for those three.
Test the A/C compressor clutch relay for continuity on the pins as shown in the service manual. Maybe even swapping the relay with a different one, etc.
Old Jun 13, 2012 | 11:49 PM
jdmcertified909's Avatar
i would disconnect every connector that goes to that wire disconnect your fans your ac clutch and connect one at a time till the fuse blows again. once your found that you know what harness to trace it to. that way you wont spend all day looking for broken or chafed wires.
JeremyGonzales
Jul 29, 2018 02:00 AM
aniskhan
11
Jul 8, 2018 02:32 PM
qpDCqp
Jun 30, 2018 02:43 PM
silver spur
Oct 1, 2007 11:27 AM
JettCRX
Jul 9, 2006 07:52 AM
