4th Gear Liberty Issues?
Old Jun 13, 2012 | 05:02 PM
JJsMotorsports's Avatar
Default 4th Gear Liberty Issues?
NOT Bashing!
I've had this dogbox for a couple of years and beat the **** out of it.......I got my money's worth.
Secondly, Has anybody had this issue?
Misalignment?
Tire shake?
Fatigue?
Tranny dog box guys please chime in! Your feedback is priceless!
Pm if you got one for sale! P#26-26
Old Jun 13, 2012 | 05:36 PM
gogetta's Avatar
Default Re: 4th Gear Liberty Issues?
Fatigue would be my first guess. What gear oil are you using?
Old Jun 13, 2012 | 06:21 PM
PRO1's Avatar
Never seen that, Wat lug dogs or those I MIT have one
Old Jun 13, 2012 | 06:36 PM
zakura R's Avatar
What final drive u have in there ??
Old Jun 13, 2012 | 06:45 PM
nonvtecallmotor's Avatar
Thats a 7 lug.
I have NEVER broken a 4th. Only time I've ever had an issue with 4th is when the top bearing broke and sent peices threw it.. I was never in 4th on that pass.
I have broke every other gear though. 3rd gear 3 times. once 1st and once 2nd.
Old Jun 13, 2012 | 09:59 PM
locash's Avatar
Without a doubt, we have had misalignment issues with 4th and a few and broken 4th's.. Major fatigue on the final drives too, they start to have small pieces missing from the pinion within 8-10 passes on 26's..
Old Jun 14, 2012 | 05:24 AM
Was using Light shock Redline (blue) then switched to HeavyShock (RED) Redline.
Old Jun 14, 2012 | 07:48 AM
JTauto's Avatar
Wierd i had the same problem too!
Old Jun 14, 2012 | 09:03 AM
redboost10's Avatar
i'd magnaflux the rest of the gear set before just getting a new fourth and putting it back together.
Old Jun 14, 2012 | 03:30 PM
SPOOLINmatt's Avatar
I use lucas 75/90 usually
I had a 3rd gear do something like that seen below. the counter side was unharmed and i reused it fortunately. I also had 4th gear strip completly off and it was misaligned like that. I machined the spacer between 4th and 3rd to realign 4th when it was all snapped in using a cut case...i used shims to makeup for the difference that i dropped the gear by on the shaft. My 4th gear lines up 99% on par now when assembled. Liberty swears up and down that their mockup in house lines up when assembled but i don't see how and showed them pics.
Old Jun 14, 2012 | 03:40 PM
my bad alignment - you can't make it perfect because of how close the dog ring is to the gear itself...you can get it real close though, much closer than they do or "did" ....i got it down to a .010" gap
my broke 4th
Old Jun 14, 2012 | 06:21 PM
I made mine line up perfectly just using shims in the correct spot. I cut up a case and put it together 20-30 til I got it right. Any time I shook the tires hard it broke..
Old Jun 14, 2012 | 07:05 PM
mine lines up "perfectly" its 10 thousandths gap. I didnt want some kind of axial movement to cause rubbing between the lugs and the driven gear. Next time it comes out im going to check for any contact, maybe shrink the clearance if its good.
Old Jun 15, 2012 | 08:08 AM
To the tooth!.....lol
Old Jun 15, 2012 | 10:02 AM
yeah thats a little out there!
Old Jun 28, 2012 | 12:28 AM
kantspell's Avatar
what kind of clutches are y'all using?
Old Jun 28, 2012 | 07:13 AM
I've used Comp twin disk, Clutch Master, Now on tilton Semi.
Old Jul 1, 2012 | 10:16 PM
kantspell's Avatar
anyone know what causes main shafts to get slightly stuck in the input shaft bearing in the bell housing?
Old Jul 1, 2012 | 10:18 PM
kantspell's Avatar
also full throttle shift? having a bit of trouble finding third sometimes
jasonp
Feb 25, 2009 08:12 PM
American.Graffiti
Transmission & Drivetrain
Oct 20, 2008 01:10 PM
snzh22
Dec 9, 2006 08:20 PM
torr
May 22, 2005 03:49 PM
