94 civic fuel pump sometimes won't prime
Old Jun 12, 2012 | 02:23 PM
GregB's Avatar
Icon2 94 civic fuel pump sometimes won't prime
We just got my daughter a 94 Civic 2 door hatch....replaced the coil and ICM...now it runs great ...... but when we start it cold (Houston TX cold) it just turns over.... We have been turning the key on and off with the clutch out until we hear the fuel pump kick in....then it starts .... but it doesn't do it on the first few tries...The old owners said the fuel pump is new...any ideas....Thanks Greg
Old Jun 13, 2012 | 05:49 AM
virgineg6's Avatar
Default Re: 94 civic fuel pump problems
Main relay may be going bad.
Old Jun 13, 2012 | 08:11 AM
Former User's Avatar
Fuel pump failure is relatively uncommon.
This^
The main relay can be resoldered:
http://techauto.awardspace.com/mainrelay.html
Also thoroughly clean (wire brush and steel wool) and tighten the G101 ground connection on the thermostat housing.
If these^ don't help, then you may need to replace the ECU.
Old Jun 13, 2012 | 09:15 AM
alston3ptswish's Avatar
Default Re: 94 civic fuel pump sometimes won't prime
Main Relay as every1 else said. Will only get worse over time, so either buy a new one for 40-50 bucks or resolder it.
Old Jun 14, 2012 | 02:35 PM
GregB's Avatar
I talked to a Honda repair shop today .... he said I should take it to a Honda dealer and have them run a check on the main computer ... He said they are the only ones that have that diagnostic tool they don't let private shops have use them....Has any one heard of this before? ... Thanks Greg
Old Jun 14, 2012 | 02:48 PM
HondaPartsHero's Avatar
Technical Hero
No its the main relay almost guaranteed, click the link in ron's post and diagnose it yourself.
Wileybuilt
Dec 30, 2015 02:04 AM
heeltoehonda
Jun 19, 2010 07:33 AM
93shadowcivic
Nov 22, 2009 01:42 PM
whitehf
Aug 6, 2006 01:22 PM
Unjockable
34
Mar 3, 2004 07:38 AM
