SRS questions
Car: '96 EX
1. Does following the 'reset' procedure actually erase the airbag deployment data from the SRS module or does it only get rid of SRS error codes?
2. Does anyone know the part numbers for the red plugs you are supposed to put in the airbags when you are working on the system?
3. Related to '2', is it truly necessary to use these plugs?
4. If you don't have the above plugs, which is safer unplugging the airbags or leaving them plugged in?
Project CTR16
Sep 6, 2010 01:35 AM
