And so it begins!
Old Jun 12, 2012 | 07:58 AM
blackbeasst's Avatar
Default And so it begins!
so i started a thread before i bought the car asking just general questions about it. this thread will be my fix/solution thread so i can keep up with everything!
on top of the antenna and clock not working, today my drivers side window got stuck half way down. local window guy said they are notorious for having problems.
just mainly a growing thread about my complaints, nothing more!
and yes, i knew what i was getting into buyin a 22 year old car
Old Jun 13, 2012 | 09:18 AM
Default Re: And so it begins!
needs a new motor/regulator. actually the lady at advance auto's 800 number hooked me up! $65 total shipped over night. not to stinkin bad since its a $106 part online!
Old Jun 13, 2012 | 09:19 AM
1991civiclx13's Avatar
pics of car?
Old Jun 13, 2012 | 10:19 AM
Originally Posted by 1991civiclx13
pics of car?
well i had some in the other post that the dealer had but he deleted them. i'll haveta get some when i get it back.
also im gonna be in the market for the cloth door panel inserts. the ones in mine are pealing off like no other
Old Jun 20, 2012 | 06:24 AM
so whats the deal with the air in these things. i see that stock they are r12 but can be converted to 134. i don't see anything under the hood that resembles a conversion. i also see that getting r12 is next to impossible and would be expensive even if i could.
so what am i looking at as far as conversion?
and maybe its just an illusion, but i swear that the air is blowing colder on the 2 right vents then it is on the 2 left ones!
Old Jun 20, 2012 | 07:31 AM
StreetsideStig's Avatar
You can get a conversion kit at a parts store for about 40 bucks, I think. If it's already been converted, there will be a sticker and an adapter screwed onto the valve.
Old Jun 20, 2012 | 11:06 AM
yeah i saw the kits. i called a couple local shops and they will do it for round abouts $200. i think this will be one thing i'll let them do for me.
Old Jun 20, 2012 | 12:39 PM
Tonyrome216's Avatar
yeah post up pics of ya car
Old Jun 20, 2012 | 01:51 PM
trust me, its nothing fancy. all stock! so don't get your hopes up when i finally do post em
Old Jun 21, 2012 | 07:10 AM
well every shop i seem to talk to about converting the ac to 134 is giving me different things i need to do.
some are saying i need to replace the dryer and some aren't. some are saying to replace the o-rings and some aren't.
the local shop that just deals with hondas/acuras quoted $300 parts and labor and includes the low pressure switch, oil, freon, o-rings, and fittings.
another local place said that unless the compressor is compatible it too will need be replaced.
so my question is, what REALLY needs to be swapped.
Old Jun 21, 2012 | 07:35 AM
It's not a bad idea. They'll evacuate the R12 legally, then pump down the system to make sure there's no air or moisture before adding the R134a. If you have the scratch, it will save you the hassle of doing the conversion yourself. I bought the kit once for my '90, but never got around to putting it in.
Old Jun 21, 2012 | 07:50 AM
yeah i wouldn't try this one on my own. im just trying to figure out what needs to be changed as i haven't been given the same answer by anyone i've called.
and just for ***** and giggles i called the honda stealership and of course they say EVERYTHING needs to come out....to the tune of $800-$1200.
anyone heard anything about freeze 12?
Old Jun 21, 2012 | 09:14 AM
quick update: its not as bad as i thought. im sure this isn't the best or most accurate way to test the temp, but i used my digital meat thermometer and when i put it on recirculation it got down to about ~43.....in the right vents. the minute i put it in the middle left vent it shot up at least 8 degrees.
not a big deal but just odd!
edit: ok i just remembered one thing, the far right vent i had closed. so that was pushing more air to the middle right. maybe thats why it was blowing colder
Old Jun 25, 2012 | 05:20 AM
What car do you have again
Old Jun 25, 2012 | 05:54 AM
90 accord ex
Old Jun 25, 2012 | 07:56 AM
also while im at it, im about down to the last bit on my first full tank. but im no where near what some people are getting as far as mpg.
i'll be lucky if i get 290 miles out of this tank which will translate into roughly 18mpg. i drive 100% around town and here recently with the ac on full blast!
how are some guys getting 25+ around town?
Declectic
Aug 22, 2013 06:03 PM
NazVil86
Sep 3, 2006 08:06 AM
type Gendy
20
Nov 3, 2004 05:20 PM
ITRbroham
Oct 23, 2001 01:19 PM
