CA NEEDGONE! 91 civic bar'd b series, b20v w/ itr head, b16 trans w/ mugen lsd ef9 front
1991 Honda civic DX BAR'd legal swap b series
NEED GONE PRICE REDUCTION 4000
Power:
OBD1 converted-
00' B18C JDM ITR COMPLETE HEAD
00' B20B High Comp block
Cable Y1 B16 trans With AUTHENTIC $1800 MUGEN LSD!
ACT Stage 1 clutch
TODA flywheel
CTR crank pulley
P08 ecu with custom base map NO CEL!
BURNS NO OIL WHAT SO EVER! TRANNY SHIFTS SMOOTH!
5w-30 royal purpal oil change THIS WEEKEND! FRESHH
3" SRI with BPI Velocity stack
Hytech Replica header -> 2.5" carsound cat -> 2.5" piping -> 2.5" ES tuning muffler.
HKS Spark Plugs
Ultimate B Racing wires
DA full radiator
HASPORT engine mounts
HASPORT shift linkage
OEM GSR shifter
Skunk2 50th anniversary shift ****
NEW OEM-
Cap
Rotor
ITR water pump
ITR timing belt
ITR oil pump
intake manifold gasket
exhaust manifold gasket
oil pan gasket
thermostat w/ gasket
valve cover gasket
SUSPENSION/BRAKES
JDM ITR TEIN RA Coilovers 14k/10k
JDM ITR Rear LCA
EG/DC front strut forks
Prothane trailing arm bushings
Prothane sway bar endlinks
Prothane front sway bar bushings
Prothane steering rack bushings
Prothane Radius rod bushings
Prothane shifter bushings
Skunk2 front camber kit
Skunk2 rear camber kit
Cusco Rear strut bar
EF9 Front brake conversion 10.4"
00' GSR Rear disk conversion
91 integra brake booster
91 integra master cylinder
91 integra 40/40 proportioning valve
15" ADVAN TOURING COMPETION WHEELS W/ LUG COVERS!
205-50-15 FEDERAL 535'S APPROX 80% TREAD
INTERIOR/EXTERIOR
REAL Nardi Deep corn 330mm
NRG short hub
NRG v2.5 quick release
91' civic SI front seats
EF9 front end conversion
EF9 cluster
EF9 arm rest
EF9 window visors
EF9 center console
EF9 complete tail lights
EF9 center garnish
EF9 rear bumper (not installed, but will give you for free if paid $5000)
EF9 spoiler
im sure i forgot a couple of things, but i will update as i remember lol.
I WILL GIVE YOU ALL THE STOCK PARTS AND SKUNK2 SPRINGS, JDM HAMP SYNERGY OIL FILTERS, AND EVERYTHING ELSE I HAVE FOR THE CAR FOR FREEEEEEEEEEEEEE
THE BAD-
all the 20 year old dings and minor dents
oxidized roof
needs driver side front wheel bearing
needs alignment
front seats have normal rips
NO JOY RIDESSSSSSSSSSSSSSSSSSSSSSSSSSS, if you dont have cash in hand ill take you for a spin. if you show me a fat wad of hundreds ill let you drive.
ill give you every reciept i can find
sergio
626.905.4420
Power:
OBD1 converted-
ACT Stage 1 clutch
TODA flywheel
CTR crank pulley
HKS Spark Plugs
DA full radiator
OEM GSR shifter
NEW OEM-
Cap
Rotor
ITR water pump
ITR timing belt
ITR oil pump
oil pan gasket
valve cover gasket
SUSPENSION/BRAKES
JDM ITR Rear LCA
INTERIOR/EXTERIOR
NRG short hub
EF9 cluster
EF9 arm rest
EF9 window visors
EF9 center console
EF9 center garnish
EF9 spoiler
THE BAD-
oxidized roof
needs alignment
sergio
626.905.4420
iheartjayDem
Jan 26, 2013 03:44 PM
iheartjayDem
Jan 16, 2013 12:50 PM
iheartjayDem
Aug 29, 2012 09:03 AM
