1994 Accord EX auto to manual swap problems *NEED HELP PLZ*
Old Jun 11, 2012 | 11:55 PM
Slammed95Cord's Avatar
Default 1994 Accord EX auto to manual swap problems *NEED HELP PLZ*
Car: 1994 Accord EX sedan, stock F22B1 Vtec motor
car was born automatic, it is now 5spd, we used a transmission off a **1992 Accord DX(non-vtec less HP motor)
I was told the ratios were almost the same for this F-series trans. and the stock F-series trans. for my car,and that i wouldnt be able to tell a difference.
ever since the swap (been about 5 years) the car has been running fine(idle and everything) up until 4k RPM. when it gets to 4k RPM... the motor completely loses power and it hits a rev limiter around 42-4500 RPMs. This happens in every gear. no CEL at any point. the RPMs dont go down, they just stop going up and reach a peak around 4200
i was told many diff things as to why this could be happening... at first i thought it was because i still had the automatic ECU in the car, well i got a 5spd one, put it in, car is doing the same thing
tested the solenoid... it clicked... drove the car with it unplugged and it was even slower, plugged it back in and it was a little bit faster but nothing really, just enough so i know it was working
the VSS is working cuz my speedo is working fine
car does still have the stock auto engine harness which has a bunch of plugs laying there that dont plug into the manual trans but i was told that was just for the auto TCU and that wasnt needed anymore
At this point im thinking the car is either in limp mode(but im getting no CEL light saying that) or its the transmission from the older car just not being setup for the newer motor... anyone got any ideas? would getting a trans. off a F22 Vtec motor my year(1994-95) fix the problem?
Old Jun 13, 2012 | 03:35 PM
Lost Again's Avatar
Default Re: 1994 Accord EX auto to manual swap problems *NEED HELP PLZ*
Did you check for codes anyway? There are some that will not set/trip the cel to come on when the car is on.
D Stevens
Jul 4, 2016 08:24 AM
NaruvariaIcaria
Dec 14, 2013 07:49 AM
kornmanz
Mar 12, 2008 06:33 PM
96blackhatch
May 31, 2005 03:08 PM
Fired Honda
May 13, 2003 10:51 AM
