EK civic wont start checked averything NEED HELP
Old Jun 11, 2012 | 10:13 PM
zack01's Avatar
Icon6 EK civic wont start checked averything NEED HELP
has anyone had this problem happen to them before
first started i drove home everthing was running fine two days later (hard rain over the weekend) wanted to start the civic it cranked over and after a while it started stumbled then died then tried starting it again fuel pump woudnt prime and the main relay started clicking like crazy an the engine check light didnt come off ... checked a couple of forums and then replaced the mian relay , ecu (when i pulled off the old ecu the terminals were abit wet) , checked the grounding on the termo and all the fuses after i done all that turned to the Ignition fuel pump started and there was spark coming from the plugs (cylinders 1 and 4 were strong but 2 and 3 were abit weak) tryed to start it again but it wont start ( it sounds like its about to start )
anyone has any ideas
cheers
egkingfl
10
Jun 4, 2011 08:39 AM
devin_hoang
11
Dec 31, 2008 06:01 PM
muhaMan
Jul 3, 2007 10:01 PM
moleodonuts
Aug 6, 2004 11:21 PM
